changing my flashed ecu back to stock for warranty work???
Old May 30, 2011 | 09:11 AM
bbsevo's Avatar
Question changing my flashed ecu back to stock for warranty work???
hey guys, thanks for taking the time to read this....
I have a flashed ecu and need to get warranty work done...they told me to change everything back to stock...so i got a new ecu same numbers and all but that car will not turn on. i put the old one back in everything is good....my question is
I was told it make it work I need to get the same ecu, mobilizer,and ignition from the same car....TRUE OR FALSE??
I would like to know so then i don't have to drop my sub fame and all that jazz.
Thanks guys
Old May 30, 2011 | 09:19 AM
pkron05's Avatar
What warranty work are looking to get done? Sounds like a bit of a hassle to get and swap ecus just to have a dealer do the work.
Old May 30, 2011 | 09:27 AM
bbsevo's Avatar
well the transfer case gasket is leaking...tranny need a rebuild....new clutch and throw out baring....now what do u think?
Old May 30, 2011 | 09:28 AM
bbsevo's Avatar
from the dealer without warranty its 10k!!!!
Old May 30, 2011 | 09:47 AM
evo8426's Avatar
You must have the same immobilizer code in the new ecu like with the old one. The only way to do that would be to flash the new ecu which is not what you wanted to do.
Old May 30, 2011 | 10:16 AM
6-speed's Avatar
Who is "they"?
The dealer?
Hard to believe a dealer would honor any warranty work knowing you are modified.
Old May 30, 2011 | 10:21 AM
bbsevo's Avatar
Originally Posted by 6-speed
Who is "they"?
The dealer?
If you must know I work for a bank which owns this particular dealership so yes to the normal person they would not do this but for me they will....so what do I gotta do??
Old May 30, 2011 | 10:25 AM
GTijoejoe's Avatar
What this guy said, you need to reflash the ecu to a stock file... you just need your immobilizer code for it to work... no big deal.
Is the rest of your car stock? I mean the ECU is not something I would think they would check right away... other mechanical mods are much easier to spot.
If your in good relations with the dealer, it probably doesn't matter either way...
In my experience, I have had my car tuned etc... and reflashed back to stock when I took it to the dealer
Old May 30, 2011 | 10:32 AM
bbsevo's Avatar
i was told not matter what once you flash the ecu you cannot reflash it back... straight from the evo tech's mouth and he is good homies with a homie of mine....once they hook their computer up to my car they see immediately that its been flashed.....to get warranty work done they need to call a specialist from up north to come and inspect it....and if there is anything on the car thats not stock he will mark it in the system as un warranty-able...so thats my drama
Old May 30, 2011 | 12:13 PM
SmurfZilla's Avatar
If you reflash the ecu back to stock you can. Deleaerships were flashing ecu's to fix a service bulletin. They may see that it's flashed but they can't say it was for performance gains. I would flash my original map back on the current ecu that starts your car and then flash it back. Hopefully you don't have so many changes that something goes wrong on the car when you do this.
Old May 30, 2011 | 12:54 PM
EvoJoeIX's Avatar
i dont understand, if the guys are doing you a favor, why would they need everything to be back to stock? its not like mitsubishi has spys that go around and look at every car in a dealership service shop
Old May 30, 2011 | 01:05 PM
bbsevo's Avatar
its because a mitsu rep needs to come down and look at any car before they can do any warranty work...why cant anyone just answer my damn question..?? I dont understand all the questions its a yes or no and then an explanation or what I can do...Im the 2ed owner of the car and the car wasn't even purchased from the dealer...hes not even supposed to do this for me but he is.
soo can anyone actually help me out?? do you know file names?? what exactly do i need to do to get this car to turn on with a stock ecu??
Old May 30, 2011 | 01:45 PM
usnevo8's Avatar
take the tcase and tranny out yourself then take it to them
Old May 30, 2011 | 02:08 PM
EvoJoeIX's Avatar
good luck getting the mitsu rep to get on board with this repair...
anyway, your question has been answered earlier. you need to get the immobilizer code from the old ecu and put it in the new ecu.... or you can just disable the immobilizer. both of which will require you to flash the ecu
Old May 31, 2011 | 05:36 PM
GTijoejoe's Avatar
Your question was answered, but you said the tech said it couldn't be flashed back.... which is not true, it CAN be flashed back, I've done it personally... does it has a flash counter? I don't know, can they tell its been flashed? I don't know... I've never seen any real data proving they can do it.....
The Rep's job is to judge if it is warrentable or not, he/she is not a tech.... and even if the rep denies you can still claim and deal with Mits. N.America by calling them... Is that enough info for you
