My Engine blew tonight!
Old Jun 2, 2011 | 09:55 PM
Hardware's Avatar
Doesn't surprise me at all. Back to the drawing board. I want a reliable DD that will put me at 11-11.5 in the 1/4 mile. I only have interest in going fast in a straight line. Will be running 93oct 100% of the time.
With the following mods below what kind of Engine would you suggest and why? Keep in mind I want to keep this reliable. Thanks for your opinions.
BR Ported 84MM FP RED
84MM FP Intake - Perrin Air Filter
BR TBE (test pipe)
BR MBC
BR Street FMIC
BR Ported Throttle Body, Intake and Exhaust Mani
HKS 272
PTE 1000cc
Megan O2 Housing
ARP Headstuds
Exedy Twin HD
Walbro 255
Synapse DV
-Brian
Old Jun 2, 2011 | 11:00 PM
evilempire76's Avatar
Whats your budget? What condition is your current motor in? Is the block, head, and crank re-useable? We need more details. Are you wanting a stroker motor?
Old Jun 2, 2011 | 11:27 PM
Evo IX MR's Avatar
Yea, you should elaborate on the matter and tell us what happened. Why are you not suprised that you had an engine failure (bad tune?)?
Old Jun 2, 2011 | 11:28 PM
AWD Motorsports's Avatar
Buschur 2.4L.. will make the most power on pump on less boost.. reliable 11s all day for a long time if tuned right...
Old Jun 3, 2011 | 12:24 AM
javicracer's Avatar
ill go 2.3 or 2.4!!!
Old Jun 3, 2011 | 12:32 AM
Evoluvin's Avatar
This^^^ or a BR 2.0!
Old Jun 3, 2011 | 01:13 AM
k20toEVO's Avatar
lol get rid of those cams and you can do that on a stock motor + good tune.
Old Jun 3, 2011 | 02:26 AM
Hardware's Avatar
I'd like to spend the least amount possible to get it running on a stock engine, but could probably handle $2-$3,000 extra on a setup that would be much safer. There is a hole in the front of the block, not sure on the head and crank. Not sure if I want a stroker motor. I honestly don't know the difference.
Hadn't been happy with the results since I modded a year ago. All I can do is laugh and move on. I don't even want to begin blaming the tune. I'd rather move forward.
New cams was my next step, but if I need a new engine anyway it might make sense to spend a little more on something better.
Old Jun 3, 2011 | 04:20 AM
SmurfZilla's Avatar
WHatever you get, over engineer the motor to handle more power then what you will through at it.
Old Jun 3, 2011 | 05:18 AM
Hardware's Avatar
I like your thinking buddy!
Old Jun 3, 2011 | 05:26 AM
ugakirk's Avatar
http://highboostforum.com/forum/show...for-your-build
That is a link that buschur tells people to check out before they decide on a new buschur engine.. It sounds like a 2.3L stroker would fit your needs.
Old Jun 3, 2011 | 07:43 AM
seqenretao's Avatar
if your block is trashed I would go 2.4 the cores on those are cheap however if your block is still good and just want to clean it up and get new internals I would go with the 2.3 cause really unless its going to live on the 1/4 mile you don't need the high revs of a built 2.0 or 2.1
Old Jun 3, 2011 | 08:02 AM
BuBBasEVO's Avatar
What mods were done to the motor ?
Old Jun 3, 2011 | 08:11 AM
High_PSI's Avatar
Those old HKS 272’s were the rage back in 2003 but a lot has changed and you need some GSC S2’s.
Old Jun 3, 2011 | 08:24 AM
Kracka's Avatar
MAP Stage 2 2.4L would be pretty sweet in an VIII.
