267whp on Dynapack
Old Dec 24, 2003 | 01:55 PM
zstryder's Avatar
267whp on Dynapack
Dunno what other people's experiences are with the Dynapack, I just got it dynoed this morning and here are the numbers:
My mods are:
HKS Downpipe
JIC 505ST catback (retain stock cat)
GReddy ProfecII EBC
SAFCII
We tried pushing the AFR's a little higher but we saw no hp gain, so we stuck with this.
I'm not particularly good at reading into dyno graphs, so maybe someone with some insight can make some comments about it... thanks!
Old Dec 24, 2003 | 02:16 PM
Quickshift's Avatar
Sweet they got there dyno running up for the EVO's. Nice numbers man.
Old Dec 24, 2003 | 02:37 PM
Mud's Avatar
Mud
hmmmm... look at your torque graph, your peaking at less than 4000rpm then its all downhill, there is defo something wrong there. The torque graph should look like the power graph
Old Dec 24, 2003 | 03:23 PM
Fourdoor's Avatar
What the hell is up with that dynapack and the torque readings? On one it says your peak torque is 335 lb-ft (Way high for a 267 HP dynapack run...should be in the mid 200's) and on the other it says your torque is 1256 lb-ft!
That HP reading is a little low...but you didn't tell what boost you are running. Also, if they can't get the torque readings correct I wouldn't trust the HP readout either.
Keith
Old Dec 24, 2003 | 03:38 PM
zstryder's Avatar
The 335 is flywheel torque. I'm not sure what wheeltorque is... I'd have to ask them how to decipher it.
I was running about 19-20psi boost to redline the entire way.
I'm starting to wonder if maybe I could have leaned it out some more starting around 6000rpms?
Old Dec 24, 2003 | 03:40 PM
nastea's Avatar
~274 ft/lb
Old Dec 24, 2003 | 03:43 PM
zstryder's Avatar
How'd you get 274?
Old Dec 24, 2003 | 03:51 PM
nastea's Avatar
with a program named calc.exe
Old Dec 24, 2003 | 04:15 PM
Chris in HB's Avatar
Aaron - when are we going to Agile to put my baby on the dyno?? I still want to go up to Pruven and do the DynoJet with Al there....
Old Dec 24, 2003 | 04:29 PM
Chiketkd's Avatar
That's awesome Alex. 267whp! You should be STI hunting now.
Hey, I shot you an e-mail.
Old Dec 24, 2003 | 05:37 PM
DynoFlash's Avatar
Find ne a clinet or two and I'll shoot back down to agile ! I am dying for an excuse to esape !!!!!!! and i ilike it at agile - me and the vin diesel look a like have some unfinhsed business with my EVO !
Old Dec 24, 2003 | 05:39 PM
DynoFlash's Avatar
PS - Agile did one of the better jobs with an afc I have seen - thats a nice looking dyno sheet considering your mods
The little bump in the trq 4500 area - thats timing
Overall a great job and they know what they are doing for sure !
Old Dec 24, 2003 | 05:54 PM
MrBonus's Avatar
I'm in a similar area.
Do you care to share your SAFC-II settings, zstryder?
Old Dec 24, 2003 | 08:29 PM
Fourdoor's Avatar
I got 270 lb-ft using the same method.... 4 lb-ft difference is all in how you look at the graphs I took it as torque peak looks to be at 3,500 RPM and then on the HP graph at 3,500 RPM you have 180 HP...plug that into the calculator and you get 270 lb-ft
Keith
PS: On a dynopack with less mods but great tuning I made 269 HP and 256 lb-ft of torque. My torque peak was a couple hundreed RPM latter and quite a bit lower. I attribute that to running completely stock exhaust and this causing slower spool up of the turbo, and more restriction in the exhaust flow over all.
Old Dec 26, 2003 | 06:31 PM
MrBonus's Avatar
Just an FYI... I ran the Buschur Turboback (No Cat), AEM Short Ram Intake, and an SAFC II that got dialed in at Agile and made 279.4. I had no boost control and was seeing stock boost levels.
I was also on the exact same dyno with probably nearly identical weather conditions.
Yank that crappy stock cat!
