please help
Old Jun 10, 2011 | 03:46 AM
lockadam2112's Avatar
please help
So I got into my car this morning and won't start I know its the switch that is under the clutch pedal.
My question is how do I bypass the switch. until my new switch comes in. Thanks
Old Jun 10, 2011 | 03:52 AM
Revo15's Avatar
what u mean by pass the switch?anyways theres a black ground wire on it top of the pedal..remove the nut and remove the wire..it should bypass n start without stepping on the clutch..hope that helped.
Old Jun 10, 2011 | 04:14 AM
I looked under there and there's no black wire just a 2 wire plug
Old Jun 10, 2011 | 04:22 AM
Revo15's Avatar
Look at the top..there is a ground wire there..check again buddy all the way at the top of the clutch pedal
Old Jun 10, 2011 | 07:51 AM
Delfast's Avatar
If you remove the ground wouldn't that be the same as unpluging it? All the ones i have bypassed u have to jump the wires. So if unpluging it doesn't work u can jump with a paper clip or piece of wire
Old Jun 10, 2011 | 02:42 PM
EVO8STI's Avatar
this sounds more like what will need to be done
