Loose Screws under valve cover
Old Jun 11, 2011 | 04:25 PM
thedru13's Avatar
Ok I changed my VC last weekend and when I was checking everything I noticed these 3 screws were super lose. I tightened them but is this normal that they get lose?
Old Jun 11, 2011 | 05:23 PM
Bobster22388's Avatar
Definitely not normal. Did you have any headwork done at a machine shop?
Old Jun 11, 2011 | 05:26 PM
thedru13's Avatar
I did not. The car has cams but had them when i bought it. So whoever did the work probably did not tighten them down. not sure but they are tight now.
Old Jun 11, 2011 | 05:35 PM
BigT's Avatar
There is no reason to touch those bolts when doing a cam swap. Unless, someone was fiddling with it and forget to tighten them back down.
Old Jun 11, 2011 | 05:37 PM
thedru13's Avatar
Cams, springs and valve seals. So IDK.. Just glad i caught it i guess. I have no clue how long I have been running with them loose.
Old Jun 11, 2011 | 05:41 PM
mitsuorder's Avatar
Maybe they had a Kiggly hla on there, swapped the old oil pressure regulator on it, and didn't tighten properly. Either way scary. Know what I have caught a few times on several cars? The little nuts on the inside of the oil cap coming loose that hold the locking mechanism to the assembly. That would just be carnage if those little guys dropped down
