invidia manifold problem
Old Jun 13, 2011 | 06:52 AM
PICASO83's Avatar
i just installed an invidia manifold on my evo 8...looks nice but the radiator top hose touches the manifold ....do i need to change the radiator?? or is there any way to fix this problem
Old Jun 13, 2011 | 06:55 AM
jdmEviL8's Avatar
you NEED to run the evo 6 radiator... no way around it. eBay has em for around $200
Old Jun 13, 2011 | 07:21 AM
PICASO83's Avatar
Thanks!! is the evo 4 5 and 6 same radiator??
Old Jun 13, 2011 | 08:11 AM
jdmEviL8's Avatar
yessir, and they are straight bolt in, its just the upper hose inlet sits farther on the driver's side
Old Jun 13, 2011 | 10:41 AM
PICASO83's Avatar
Old Jun 13, 2011 | 11:04 AM
Jossue's Avatar
Or if you have the means the CBRD radiator works awsomw and it's thinner as well.
Old Jun 13, 2011 | 12:27 PM
CBRD's Avatar
let me know if we can help!
cb
Old Jun 13, 2011 | 12:33 PM
Vehicle336's Avatar
cb
HEEEEEEEE'S EVERYWHERE....... WATCHING, WAITING!
AAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH H!!!!
Op, post up some pics, I want to see how close that bad-boy gets. Also, would it be worth it to get a set of some SAMCO hoses? Do they deflect the heat a bit better?
Old Jun 13, 2011 | 02:02 PM
CBRD's Avatar
yep!
always here to provide the right solution
we just did a stock housing turbo setup- car has a koyo, its even close!
cb
Old Jun 13, 2011 | 02:32 PM
reboundicon's Avatar
Like mentioned above, there are other shorter route rads that have a straight rad pipe more far away from the manifold. Also you can get the stainless steel rad hoses available as well.
Old Oct 7, 2012 | 10:52 PM
hermin0000's Avatar
I'm about to pop on an invidia exhaust manifold in the for sale section. The dude selling says he has a coolant hose that will fit around the manifold. Can this be? Everyone on this thread seems to say that I need an entirely new radiator to run this invidia ramhorn twinscroll manifold?
The add is titled "bunch of evo 8 performance parts."
Thanks.
Old Oct 7, 2012 | 11:01 PM
fastyouth1313's Avatar
Here what you can do. Cut about half inch off each end and kinda pull it to make it fit and use band clamps to hold it on. It's a temp fix/work around. You child do a half rad or the evo 4 5 6 rad. But you can get away with temp fix for awhile
Old Oct 8, 2012 | 09:02 PM
hermin0000's Avatar
Thanks for the advice but I'm really looking for a long term solution. He claims to have a radiator pipe that will fit around it. Does this seem right?
Old Oct 16, 2012 | 06:08 PM
racas's Avatar
i believe thats correct....he has the pipe listed for sale as well. I'm chiming in because i was looking at the same ram horn mani
Old Oct 16, 2012 | 07:57 PM
Tekniq's Avatar
Can't the evo 8 run the 2003 acura RL radiator?
