Aem boost gauge
Old Jun 29, 2011 | 06:46 PM
  #31
clubEVO93's Avatar
Have you had any problems with the way you have done it? and what fuses did you use?
Old Jun 29, 2011 | 06:50 PM
  #32
rush63's Avatar
Originally Posted by Nashou66
Not true, My gauge came with all the hardware needed to install this. The Map sensor came with an adaptor also that screwed into the larger AN fitting and the hose supplied and Tee fitting both fit the hose and the stock hose I taped into.
I got mine from Lancershop and it was all included in the AEM box.
Athanasios
Not true for you but true for me! I don't care where you bought yours!
Old Jun 29, 2011 | 06:56 PM
  #33
rush63's Avatar
I pulled one of the Fuses out and sandwiched the power wire for the gauge behind the fuse as I pushed it back in. But they make Piggy back fuses that have a wire coming out of it to use to power accessories.
Click picture for link:
Athanasios
Be specify because not all of the fuses will work for right for the gauge.
Old Jun 29, 2011 | 06:59 PM
  #34
clubEVO93's Avatar
I have a boost and wideband gauge im trying to power up here. Can one fuse power both?
Old Jun 29, 2011 | 07:12 PM
  #35
Nashou66's Avatar
I don't remember which spot I used . I used my Multimeter to find a 12 volt hot while when the key was in the on position.
Regarding the fitment of the Map sensor Rush, mine and most others here have had their AEM gauges come with all hardware needed. It is possible yours was returned and re sold to you with out the seller checking the contents of the box before they restocked it.
Athanasios
Old Jun 29, 2011 | 07:21 PM
  #36
rush63's Avatar
^^You maybe right as I bought mine on sale for $110
With regards to the fuse, I used the one on the top left of the fuse box. That's constant power and doesn't turn off when you start the engine.
Old Jun 30, 2011 | 07:00 AM
  #37
clubEVO93's Avatar
Im guessing that its a square gray one? if not what color is it? and whats it look like?
Old Jun 30, 2011 | 07:21 PM
  #38
clubEVO93's Avatar
Ok so i got one of the fuses that you can use for gauges and i got everything hooked up and wired and turned the car on the and my boost gauge is stuck between 2 and four. my wideband works great.
Old Jul 1, 2011 | 11:21 AM
  #39
ArmedEscort's Avatar
I did it off of the cig lighter.
Old Jul 1, 2011 | 01:31 PM
  #40
clubEVO93's Avatar
Im stuck on my boost gauge still idk why its stuck Idk if its messed up or what and now also my factory boost gauge isnt working can someone please point out where the fuel pressure line is? on there own pictures or on the pictures from page two.?
Old Jul 1, 2011 | 05:49 PM
  #41
X91EVO's Avatar
Registered User
maybe you have a giant boost leak haha
its on the left of the motor on the left end of the fuel rail
bell shape fpr
Old Jul 13, 2011 | 08:56 PM
  #42
clubEVO93's Avatar
ok. so it was right the whole time MKC verifed that it was. But right now its stuck on 4 and 2 some im about to rip the B***h up out of there and send to AEM for a check up. and just buy a defi blue racer.
Old Jul 21, 2011 | 11:39 AM
  #43
asu11's Avatar
I drilled a 1/2 " hole right next to the steering column. I noted how the wires in the one Cable from the MAP sensor to the Gauge were positioned in the connector. I then removed the pins from the Molex connector and fed the wires into the cabin. Reconnected the molex and pins and fed the wire up to the gauges on my column . Easy
Athanasios
What gauge pod is this?
minimarine09
For Sale - Part Outs
Mar 14, 2017 12:02 PM
roidz3
Oct 2, 2016 08:55 PM
TxFAkuma
May 11, 2016 06:26 AM
needsboost
Mar 7, 2016 10:18 AM
abosoxfan4life
Dec 2, 2015 02:21 PM
