Boost Leak Test FAILED! HELP.
Old Aug 31, 2011 | 02:28 PM
  #61
1UpMoto's Avatar
Originally Posted by benselements41
I'm no ASE master TECH, but if there is an exhaust valve open just enough to get air through and the intake valve is open too....... air will get through.
intake and exhaust valves should not be opened at the same time.
Originally Posted by EvoJoeIX
no it wont.
YOU ARE NOT PRESSURIZING THE ENGINE.
air starts at the compressor housing and ends at the throttle body. it does not go through the engine
Wrong air does not stop at the throttle body, how do you think it is possible to idle with the throttle closed? Air will pass the TB when its closed.
Old Aug 31, 2011 | 09:01 PM
  #62
awdordie's Avatar
OMG stop going around posting useless information in everyones threads. First about how all 2003 evos have clear coat and is not a single stage paint job, WHICH IT IS A SINGLE STAGE PAINT JOB AND DOES NOT HAVE A TOP LAYER OF CLEAR COAT UNLESS ITS TB OR GG, and now saying exhaust valves and intake valves shouldn be open at the same time. Ever heard of valve overlap genius? And yes enough air does stop at the throttle body when its closed to perform a boost leak test.
I swear evom moderators need to make an exam up so that you have to have a certain level
of knowledge of a motor and car, especially if its your own car, to post in here. And if you can't pass the exam you should only be allowed to READ and LEARN BEFORE POSTNG FALSE INFORMATION.
Old Aug 31, 2011 | 09:22 PM
  #63
awdordie's Avatar
here ya go 1upmoto just for you i will take the time to enlighten you after every stupid post you make not knowing what your talking about.
http://lmgtfy.com/?q=define+valve+overlap
Old Sep 1, 2011 | 07:41 AM
  #64
1UpMoto's Avatar
Im not retarded, I know what valve overlap is. We are talking about boost leak tests here and 99.9% of the time with the car off their should not be any overlap. Air gets passed the throttle body How the hell do you think you find boost leaks on the intake manifold, and its funny that my boost gauge rises as I pressurize the system, but I guess thats impossible since it stops at the TB. Also I know apex silver, TB, GG, are not single stage.
commbubba19
May 9, 2016 08:15 PM
asu11
May 1, 2014 06:54 PM
steven121
Aug 16, 2013 08:05 AM
AdamRA
Aug 30, 2010 08:09 PM
Ted B
Feb 17, 2010 08:52 PM
