Turbo??
Old Jul 4, 2011 | 08:33 PM
miketurbo06's Avatar
Turbo??
Can an Evo reach 500HP with the stock turbo???
Old Jul 4, 2011 | 08:47 PM
JohnDoe1984's Avatar
It's possible and has been achieve on only the most completely stretched to the limit setups running e85 on max boost kill mode tunes with full port work and fuel upgrades. Most people cannot achieve that kind of power on a stock turbo though. You're also going to need a built bottom end most likely. The torque is going to hit hard and fast on the stock snail.
http://www.youtube.com/watch?v=WUkXSFmJg1I
Here's english racing doing it.
400 is a more realistic limit for most people and at that level you will probably burn out the turbo quite quickly.
Old Jul 4, 2011 | 10:38 PM
italianevo88's Avatar
You might get bombarded with the phrase "search first" because there are tons of dynos of stock turbo cars etc and im sure this has been covered before.
Also your question is pretty vague.
500 crank horse power? 500 dynojet? 500 mustang? 500 safely? if you were more specific it would be a little more helpful. But 500 crank horsepower is totally possible, 500 dynojet, also not too unbelievable, 500 mustang... probably not likely that the turbo will last long, but im sure its been done.
Old Jul 5, 2011 | 12:53 AM
ahmed718's Avatar
With an bigger wheel and e85 yes..
Old Jul 6, 2011 | 10:52 AM
IbeBOOSTIN's Avatar
It's been done but how deep are your pockets?..
And jus don't expect it to last too long you'll be upgrading
Eventually..
Old Jul 10, 2011 | 11:52 AM
Tatmonster45's Avatar
That turbo will be way past it's efficiency range and will go bad quickly working it like that. And 500 hp stock Evo engines don't last long either. I don't care that there's people making that and more. It will not last over 40k
Old Jul 10, 2011 | 11:59 AM
Drifting Away's Avatar
Yea, its been done, but I dont see the need of pushing the turbo that far. At that point I would just go with one of the stock frame upgrades and or a t3/t4 setup. just my $.02
Old Jul 10, 2011 | 03:02 PM
RockmanX's Avatar
yea you need a fully built car to do that i dont see you spending 20k+ just to keep the stock turbo unless your a shop and just want the record on top of that you will hit that 500 but boost power etc will fall off quickly so you will not be there long enough to care.
Old Jul 10, 2011 | 03:27 PM
FERNO's Avatar
Originally Posted by RockmanX
...but boost power etc will fall off quickly so you will not be there long enough to care.
OP, as most have said, SEARCH. There are many threads on the limits of the stock turbo. You are way out of the stock turbo's efficient range and it will fail prematurely. Since you have a IX turbo, search a bit and I bet you will find an option or two.
Old Jul 22, 2011 | 05:49 PM
sschwoegler's Avatar
Sounds like a lot of work. Whats holding you back from a larger turbo?
Old Jul 22, 2011 | 05:54 PM
roostinds's Avatar
Yea if you looking for 500 whp why not go FP black?
Old Jul 22, 2011 | 06:10 PM
fp black
Fuego
For Sale - Part Outs
Oct 18, 2016 10:12 PM
Freddy302
Oct 11, 2016 05:55 PM
Seenoevol
Jan 28, 2015 05:14 AM
clubEVO93
Sep 22, 2010 07:41 PM
Kaymo
Lancer Aftermarket Forced Induction Tech
283
May 3, 2005 10:23 AM
