maf what to do with it
Old Jul 14, 2011 | 09:39 PM
dinoz1980's Avatar
hi all im still new to this so im sorry if this is in the wrong place now im in the middle of my build and i am doing a 2.4 motor sbr stage 3 ported head and a stm forward facing 6262 turbo now today i was just looking over things and i came across something i didnt think of be4 with the turbo up front what do i do with the maf senor now any help or info thanks guys
Old Jul 14, 2011 | 09:58 PM
EvoJoeIX's Avatar
you cant run a MAF on a forward facing turbo set-up
you need to go speed density on the stock ECU or get an AEM or another aftermarket ECU
Old Jul 14, 2011 | 10:21 PM
dinoz1980's Avatar
thanks thats what i was thinking but wasnt sure if i could do that with the stock ecu so where do i put the speed density im think on the upper ic pipe and then do i just tap into the old maf wire with the new sd wire
Old Jul 14, 2011 | 10:34 PM
EvoJoeIX's Avatar
all you need for speed density on the stock ecu is a omni 4 bar map sensor. then you need to have you ECU flashed with the speed density stuff. check on the tuning section for more info on it
Old Jul 14, 2011 | 10:45 PM
dinoz1980's Avatar
thanks joe thats was more help than you know
