AEM oil press gauge
Old Jul 24, 2011 | 09:25 AM
asu11's Avatar
AEM oil press gauge
Looking into getting the aem oil press gauge. Does anyone know if it comes with the sender and everything? Their site doesn't say much. Also it comes with values of up to 100 & up to 150 psi. Is it necessary to get the 150? Same cost.
Old Jul 24, 2011 | 10:03 AM
Toole's Avatar
if it's the same cost, why not just get the 150psi one and be on the safe side?
Old Jul 24, 2011 | 10:08 AM
nytalonTSi's Avatar
Same price, just get the 150psi. Even though the one 100psi one is enough.
Highest I see is on a cold start is below 100psi, or if I'm doing like 80-90mph on thruway. Stock motor.
Old Jul 24, 2011 | 10:13 AM
asu11's Avatar
Yeah makes sense. Anyone know if its the full gauge kit though?
Old Jul 24, 2011 | 10:14 AM
erald01's Avatar
I would not get a 100 psi gauge since you already reading 85-90psi on a start up or at highway cruising. Get a 150psi, and yes comes with everything. I was going to get the AEM, but ended up with a prosport one its just as good, and for a lot less....you need this though an 1/8" NPT Oil Pressure Adaptor for the oil filter housing...here where i got mine from http://store.42draftdesigns.com/Excl..._c_23-2-0.html
Old Jul 24, 2011 | 10:17 AM
asu11's Avatar
Thanks for the input. Happen to know if theres an oil gauge install thread?
Old Jul 24, 2011 | 10:31 AM
erald01's Avatar
yeah but installing is the easy part, no worries there. There is directions with the gauge.
Old Jul 24, 2011 | 10:41 AM
asu11's Avatar
Cool thanks!
Old Aug 27, 2011 | 12:21 PM
asu11's Avatar
Ok well I ordered my aem oil pressure gauge and am not sure what adapter I need for the oil filter housing. Is it npt or bpst adapter because aem is not listed on their site. Thats all I should need to do the install correct?
Old Aug 27, 2011 | 01:09 PM
Spec-Ops1's Avatar
the 42 draft designs NPT adapter... if I were you I would ge the AMS remote oil pressure sender line... http://www.amsperformance.com/cart/A...Unit-Line.html
Old Aug 28, 2011 | 11:35 AM
asu11's Avatar
So if I order that ams adapter is that all I need to do the install? No other fittings?
Old Aug 28, 2011 | 11:51 AM
sujinX's Avatar
the description says it comes with appropriate fittings on each end. so im guessing yes.
Old Aug 29, 2011 | 12:57 PM
Spec-Ops1's Avatar
Correct all fittings included...
Old Aug 31, 2011 | 06:38 AM
spooldursti's Avatar
The fitting that comes with it will screw right into the oil filter housing. Its a pretty straight forward install. The only problem I had was the wires weren't quite long enough, so I had to cut the wires about 6 inches from the plug and extend them 18 inches or so just to be safe. I rolled up the excess and zip tied it above the K member and done.
I also went with the 150psi sender just to be sure if I ever had any sudden oil psi spikes I would know.
Old Aug 31, 2011 | 07:02 AM
asu11's Avatar
Thanks for all the responses! Im going to buy that ams kit just to be safe and so it gives me a little more added length for the install.
