change odo on cluster
Old Jul 24, 2011 | 09:02 PM
boczo777's Avatar
as above, is it possible to do it???
Old Jul 24, 2011 | 09:10 PM
Raistlin's Avatar
I assume this is because of getting a different cluster?
I believe you have to take it to the dealership and have to get proper paperwork done. But yes it can be done, I recall reading about the stuff needed on here before.
Old Jul 24, 2011 | 09:52 PM
ProPilot04's Avatar
You need paperwork and a shop has to do it or it's illegal.
Old Jul 25, 2011 | 12:49 AM
Pusha's Avatar
Not possible to just swap out the entire cluster? They should all be plug-in-play...
Old Jul 25, 2011 | 01:01 AM
Raistlin's Avatar
The milage is stored in the cluster.
If you just swap a cluster your milage will read differently than the one you took out.
Old Jul 25, 2011 | 01:24 AM
OZR_Lancer's Avatar
as an example...lot of us base models run diff clusters from stock.. es guys have oz clusters or es/oz are running evo 7/8/9 clusters.
clusters are plug and play but majority of them [ ones who swap out the clusters ] if not all are way off on milage.
the only time i can see a problem if u try to sell the car with a odo where its milage is way off. even if u swap out the cluster u still have to have it reprogramed...
i put in a evo8 odo in my oz and it works just fine, i waited 3k miles to install it so i can have the milage be %100 accurate.
i been runin mine for close to 20k miles and have no issue as all.. when i recieved it i swapped it in quick to do a post and got a odo reading and then i waited 3k miles i think to put it in for good. marked the odo so when my oem odo hit that mark, i literly went in house at 10pm at night to get cluster and install it in street
Old Jul 25, 2011 | 03:29 AM
Drifting Away's Avatar
Why would you want to do this anyway?
Old Jul 25, 2011 | 07:17 AM
boczo777's Avatar
i bought another cluster that is more than my car
Old Jul 25, 2011 | 12:59 PM
Coney Warrior's Avatar
You also have to remember that mileage is also stored in the ECM, so when the shop resets the mileage on the cluster, they also have to match it to the ECM if its the OEM one to the car.
Old Jul 25, 2011 | 01:03 PM
metalsaber's Avatar
ONly legal reason would be because the original one wasn't working.
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Feb 21, 2014 07:43 PM
