help ARP.. MAP?
Old Aug 2, 2011 | 02:52 PM
polish_pounder's Avatar
help ARP.. MAP?
Hey guys so i finally have all the pieces i need for my small little install i am doing my car hit 60k last month and i have been waiting for all the parts to arrive so i can do my maintenance kit with the timing belt balance shaft all of that stuff. i have been gathering parts for my cams. i purchased Kelford 272's and supertech dual springs and retainers i have also a new headgasket but i was wondering what headstuds to run? i was told that the MAP headstuds have a better design and looking at their description of the design i agree but they are cheaper than the ARP so i was wondering if they are truly better. any info on headstuds would help alot thank you~!
Old Aug 2, 2011 | 08:53 PM
anyone?
Old Aug 2, 2011 | 09:22 PM
RSMike's Avatar
are you talking 8740 metal or H11/L19?
http://www.maperformance.com/map-hig...11mmalloy.html
or
http://www.maperformance.com/map-ult...11mmhdstd.html
just because it's cheaper, doesn't mean it's worse I would go with MAP, they have great products
Old Aug 2, 2011 | 09:51 PM
DubsE46's Avatar
MAP has quality products at a fair price
Can't go wrong with MAP
Old Aug 2, 2011 | 10:52 PM
Teal2nnr's Avatar
I'm sure with either you'll be find. I personally run L19's.
Old Aug 3, 2011 | 05:36 AM
thanks guys but what about a head gasket? What is better oem or would I be ok with me a cometic? If I get a cometic do I have to get my head machined?
Old Aug 3, 2011 | 06:50 AM
jvlazzar's Avatar
why did you buy dual springs to go with Kelford 272s?
Old Aug 3, 2011 | 07:46 AM
Because I got the dual springs for a steal why?
Old Aug 3, 2011 | 08:09 AM
selecta's Avatar
No need to change the head gasket for cams/springs install.
Old Aug 3, 2011 | 08:16 AM
i am doing headstuds tho so i do need to so i was just going to get the cometic head gasket
Old Aug 3, 2011 | 08:18 AM
teribble's Avatar
MAP L19's here and won't go any other way!
Old Aug 3, 2011 | 08:20 AM
But what about headgasket is Cometic Better than OEm?
Old Aug 3, 2011 | 08:40 AM
SmurfZilla's Avatar
No.
Power Enterprises is better. That being said I have a Cometic that was fitted but never used for sale....LOL.
OEM head gasket is good until you start going past 550+
Supertech Duals are find for kelford 272's. I certainly wouldn't run stock valve train with them. I had Kelford 272's and swapped the valve springs at the same time for supertech duals.
Old Aug 3, 2011 | 09:00 AM
Originally Posted by SmurfZilla
No.
Yeah i already ordered the Cometic From MAP... So im getting that and the Headstuds. Sorry ahha
And u mean my setup is fine u wouldnt run them without springs and retainers right?
Old Aug 3, 2011 | 09:19 AM
Ev0ikon's Avatar
I always had better luck with stock MLS head gaskets than those from Cometic.
