help ARP.. MAP?
Old Aug 8, 2011 | 08:08 PM
Evo03Rt's Avatar
the stock headgasket is the best they run them in linke 1000hp evos no need for any aftermarket ones and the map l19 are really good never had any problems
Old Aug 13, 2011 | 08:31 AM
jvlazzar's Avatar
Originally Posted by polish_pounder
Yeah i already ordered the Cometic From MAP... So im getting that and the Headstuds. Sorry ahha
And u mean my setup is fine u wouldnt run them without springs and retainers right?
Kelford recommends Beehive springs with their 272's, NOT duals. I'm sure it will be fine, but just an FYI...
https://www.evolutionm.net/forums/8270344-post17.html
Old Aug 13, 2011 | 12:30 PM
polish_pounder's Avatar
I understand that but I can't afford them I got these duals for a steal. Plus they are better than nothing and people almost everyone on here says I don't even need to upgrade my springs. But I know where you are coming from but I can't afford them atm so im gonna have to stick with what I have
Old Aug 13, 2011 | 12:46 PM
djikonatx's Avatar
so what would you guys go with? l19s or h11 from map?
Old Aug 13, 2011 | 02:12 PM
jvlazzar's Avatar
understood...most times duals and pricier than beehives, so if you got them cheaper more power to you!
Old Aug 13, 2011 | 02:59 PM
mitsuorder's Avatar
I like the tooling steel (aka h11/L19) offerings from either Map or Cosworth. Reason being is that they both have tapered tips which allow them to fully seat into the base of the bore. This prevents a gap from being left which can eventually compromise clamping force.
Old Aug 13, 2011 | 03:45 PM
Thanks man hey how much power are u making? I seem to have a similar setup or howmuch power did u make from the cams
89turbosupra
Oct 9, 2015 09:51 AM
fortyPSIrs
55
Apr 16, 2014 10:02 AM
jason42003
Dec 22, 2013 02:34 PM
icmanevo
11
Sep 21, 2012 12:55 PM
aschold
40
Nov 28, 2009 03:17 PM
