AEM Wideband flat lines at "10.0" Boost Leak? Tuning problem?
Old Aug 5, 2011 | 06:04 PM
GTijoejoe's Avatar
Originally Posted by razorlab
Not correct. On a wideband gauge, set to gasoline reading, 10 is about 2 points too rich for WOT operation on E85.
Not correct. Stoich is the same 1 lambda no matter the fuel you run. On a wideband gauge, set to gasoline reading, stoich is 14.7 AFR (1 lambda) no matter the fuel you run.
E85 wot fueling, On a wideband gauge, set to gasoline reading, should be around 11.5-12.5 AFR depending on tuning strategy.
I think I was not clear, lambda is always the same as that is what 02 sensors read, but stoich for the intent of fuel you are using changes. Ethanol I believe has a stoich of ~9:1.... and as you stated pure gasoline is 14.7:1... when you mix these fuels the stoich values lowers depending on the % fuel mixture... so for an exampe E10.. stoich is more like 14:1 or something like that as its not 100% pure, understood that lambda = AFR/stoich AFR, innovative motorsports has a small write up about this some where.
Old Aug 5, 2011 | 06:54 PM
RazorLab's Avatar
Stoich is 1 Lambda.
1 Lambda on a Gasoline set wideband is 14.7, which is stoich, and is 1 lambda.
Old Aug 6, 2011 | 05:39 PM
GSX 911's Avatar
Thanks, my mechanic is going to check it out next week.
Old Aug 6, 2011 | 07:21 PM
cobb_sti's Avatar
any conclusion yet?
Old Aug 9, 2011 | 08:43 PM
GSX 911's Avatar
Originally Posted by cobb_sti
any conclusion yet?
Its at my buddys house at the moment, he thinks it might be a fuel injector
beasters
Dec 31, 2018 10:57 AM
eddy5201314
Feb 3, 2017 04:37 PM
duranvw
Sep 18, 2016 09:27 AM
whtjoe
Jul 20, 2015 04:40 PM
03BBY1088
Jun 14, 2014 11:32 AM
