Leak
Old Aug 11, 2011 | 08:27 AM
asu11's Avatar
Leak
I just picked up an 06 mr and have a leak from the reservoir on the driver front side of the hood. It says diff on it. Is this a common problem? Do I just need to switch out the reservoir?
Old Aug 11, 2011 | 08:58 AM
geevolution's Avatar
Round, white, pink fluid? If so that's your ACD reservoir, might want to make sure it's just the reservoir and nothing else that's leaking.
Old Aug 11, 2011 | 09:36 AM
asu11's Avatar
I think. I know if your standing in front of the car its right at the front right. Its a small round reservoir and i believe the fluids pink. I can see it leaking at the bottom of it by the lines. Its still pretty full but needs fluid. What fluid goes in there?
Old Aug 11, 2011 | 10:14 AM
https://www.evolutionm.net/forums/ev...acd-fluid.html
Old Aug 12, 2011 | 07:01 PM
asu11's Avatar
Well the leak is right by the driver side tire so im guessing its the resovior not anything else. Anyone have this problem? Also where can I get the acd fluid?
Old Aug 13, 2011 | 12:24 PM
asu11's Avatar
ANyone know if its ok to mix acd fluids as long as theyre the same type?
Old Aug 15, 2011 | 06:10 AM
I wouldn't mix, but that's just my opinion. Put it this way, if you're low on oil and you've been using Mobil 1 10W-30, would you pour in a different brand 10W-30?
