ACD Fluid
Old Jan 8, 2005 | 09:14 AM
oguratevo's Avatar
ACD Fluid
The manual states that use ATF SP III for the ACD fluid, is this the same as the auto-trans fluid? Thanks.
Old Jan 8, 2005 | 12:12 PM
EVOTEXAS's Avatar
ATF = Automatic Transmission Fluid
Old Jan 8, 2005 | 07:46 PM
gunzo's Avatar
ACD doesn't use ATF .. AYC does .. the ACD pump uses ATF SP III .. but don't change that unless your ACD light comes on like a christmas tree or you hear funny noises ..
People will give you the bullsh*t about needing to bleed the ACD regularly .. don't listen to that .. it's like your brakes .. you don't bleed it unless you have problems .. or you change clutch
editted to add : Just be clear here .. ACD uses normal SAE gear oil , ACD pump uses ATF SP III (but like I mentioned no need to change unless...)
Old Jan 8, 2005 | 09:45 PM
Celm's Avatar
wow the ACD in the US cars isnt the same as the JDm and euro evos
Old Jan 8, 2005 | 11:33 PM
gunzo's Avatar
IS IT ?? Base on what ?? you'd think Mistubishi is stupid enough to make 2 difference types of ACD just to make sure the USDM evos are the lowest of all the grades ?????
Old Jan 9, 2005 | 06:29 AM
Celm's Avatar
there are two different types.u look at the current JDm/euro evo 8 or MR,or even the 7.there is no resivour in the engine bay for the ACD.the acd runs its normal gear fluid self contained in the tranfercase.only resivour in the car that uses ATF SP III is its AYC in back.
Old Jan 9, 2005 | 06:46 AM
gunzo's Avatar
don't confuse the issue here .. the guy asked ACD .. not AYC .. THERE IS NO RESERVOIR FOR THE ACD .. but the ACD pump runs on ATF SP III
ok .. make it clear .. there's 2 PUMPS on board .. for ACD / SAYC cars .. there's only 1 PUMP if it's ACD only .. and this is also a possible config in JDM cars ( ACD and rear LSD diff .. mostly in RS models)
Sigh .. why argue .. you guys got the tech manuals online .. just check it out ..
Old Jan 10, 2005 | 10:20 PM
oguratevo's Avatar
The reason why I'm asking because my ACD reservoir level is at the low level, I'm planning to top-off to the max level. I better check the level it again. Thanks for the info.
Old Jan 10, 2005 | 10:22 PM
oguratevo's Avatar
My '05 MR has an ACD reservoir, it is located in place of the intercooler water spray resevoir found on the '03-'04 USDM Evo's.
Old Apr 5, 2013 | 09:00 AM
dave_evolvix's Avatar
Bumping this discussion back up from the dead...
I have a similar "low" level in the ACD reservoir on my Evo IX. The cap says ATF SP III which is automatic trans fluid.
But, if I change the transfer case oil (from below) it will be Diaqueen/Redline/Amsoil 90w.
Am I correct?
Old Apr 5, 2013 | 09:49 AM
thedru13's Avatar
The resi uses ATF the Trans Case uses the Diaqueen..
Am I correct?
Old Aug 31, 2013 | 11:46 AM
Luis_alexis's Avatar
I have the same issue, filled it with atp about a 2 weeks ago and now is back at the second line,��
Devesh Budhram
Dec 30, 2016 03:21 PM
Viegasjuice
Oct 12, 2014 06:45 PM
Gqracer
Apr 5, 2013 08:50 AM
Blue Evo 8
12
Mar 4, 2013 11:13 PM
heingtaing
15
Mar 4, 2011 09:12 PM
