how to change acd fluid?
Old May 24, 2008 | 07:09 PM
heingtaing's Avatar
I was able to change my Tranny, tcase and rear dif but not sure how to change the acd fluid. Does anyone have a diagram or pics of how to do this?
Old May 26, 2008 | 03:04 PM
heingtaing's Avatar
bump
Old May 26, 2008 | 03:19 PM
shunderwunder's Avatar
There is a bleeder screw on the bottom of the transfer case. I would suck out as much of the old fluid from the resivoir as possible & top it off with fresh to start. It helps to have someone in the car while you loosen the bleeder. With the bleeder open turn the ignition on, but dont start the car. Then press the gas pedal to the floor this will cause the ACD pump to run for a few secconds & push the fluid out the bleeder. you will have to cycle the key & press the pedal again a few times to get all the fluid out. Make sure you keep an eye on the fluid level cause you dont want air in the system. Hope this helps. It's pretty easy.
Old May 26, 2008 | 07:45 PM
biggie5252's Avatar
Are you supposed to change the ACD fluid on a regular basis?
Old May 26, 2008 | 08:07 PM
I dont think it needs to be changed regularly, but I would do it every 50k or so. It definately wont hurt. I did mine cause I dissconnected the line to the transfer case when I did the clutch.
Old May 27, 2008 | 06:50 AM
biggie5252's Avatar
I see. Thanks!
Old Jun 11, 2008 | 03:52 PM
owenxguo's Avatar
oh, so ACD and TC fluids are separated? I thought they are the same thing. So is redline shockproof ok for TC? I'v heard they are not good for tranny cuz they eat up syncros.
Old Jun 19, 2008 | 04:51 PM
fluxcapacitor's Avatar
bumpp for acd
Old Jun 21, 2008 | 04:36 PM
red evo8's Avatar
Hm i was convinced that it was one o those things that never gets changed.
Old Jun 22, 2010 | 08:52 PM
highbredcloud's Avatar
Anyone know what fluid needs to be used for the ACD? I thought it was the same thing as the LSD fluids...mitsu Diaqueen? no? Also does it need to be bled...or can you just pour some in the resevouir if you are low?
Old Jun 23, 2010 | 06:40 AM
Davo's Avatar
ACD is Diamond SPIII or ATF+3/+4
Old Feb 21, 2011 | 06:17 PM
spyda494's Avatar
I need to refill my acd fluid. Where can I buy some?
Old Feb 25, 2011 | 06:18 AM
Davo's Avatar
at the mitsu dealer or your local parts store
mitsu is diamond spIII or atf+3/4 is the equivalent in the parts store
Old Feb 26, 2011 | 07:34 PM
spyda494's Avatar
Thanx. Mitsubishi had it for $10 a quart
Old Mar 2, 2011 | 03:28 AM
evo8john's Avatar
Holy crap! $10 a qt! I would just get some nice atf from the parts store for much less money... It just acts as a hydraulic fluid iirc.
