Question about acd fluid
Old Jan 5, 2014 | 07:28 PM
Viegasjuice's Avatar
I was curious if the acd reservoir fluid is solely for the acd or does it provide fluid for anything else. Thanks for helping a noob out
Old Jan 5, 2014 | 07:55 PM
InsanePain143's Avatar
It's just for the ACD
Old Jan 5, 2014 | 08:11 PM
Thanks man! What's the most recommended to use.
Old Jan 5, 2014 | 08:56 PM
Raptord's Avatar
Use OEM stuff, I don't even know of any aftermarket equivalents.
OEM stuff is Diamond ATF SP III - part number ACH1ZC1X05
Old Jan 5, 2014 | 08:57 PM
I use Mitsubishi Diamond ATF SP III. I have heard of others using some type valvoline of valvoline or redline ATF though.
Old Jan 5, 2014 | 10:07 PM
Thanks guys, to be clear I haven't heard of anyone doing fluid changes on the acd?
Old Jan 5, 2014 | 11:36 PM
TommiM's Avatar
After trying out various fluids I say stick with oem. If I recall the equivalent is chrysler atf +4 ATF.. Ive used Castrol,redline, and oem. They all worked fine but I would recommend the oem stuff.
As far as changing/flushing out the fluids, its easy to service. You can suck some out of the reservoir, open up the drain nipple on the transfer case, close it back up, top off, prime the pump, check the fluid level, prime again, check fluid level again, repeat as needed.. To prime, just put the key in position 2, push the accelerator pedal to the floor and hold It for a few seconds. The pump will run for a few seconds and shut off by itself, then you can release the pedal and check your fluid levels.
I bled it like this after draining my system when I relocated my acd pump. It Bled good and working fine.
Old Sep 25, 2014 | 05:02 AM
Atrophical's Avatar
Does this need to be flushed at certain times? I have 113k on her now and I haven't once touched the ACD setup or reservoir.
Thanks!
Old Sep 25, 2014 | 06:33 AM
TommiM's Avatar
Thanks!
According to Mitsu you don't need to ever flush it. I'm not a believer in lifetime fluids though. At the very least I would just suck out and replenish the fluid in the reservoir. That will get like 80% of the fluid from the system. The acd system doesnt use up a whole lot of fluid.
Old Oct 10, 2014 | 08:10 AM
viprez586's Avatar
There has been a lot of debate over the Mitsubishi SP-III having very poor cold climate viscosity.
However it's very difficult to find the MSDS sheet or any info on the fluid.
However SP-III is the same fluid used in Kia/Hyundai/Mitsubishi automatic transmissions.
Luckily there are tons of compatible fluids. The redline D4 fluid and the royal purple max atf have very superior cold climate viscosities and I'd highly recommend that if you run your car in cold climates.
This in turn will help the pump operate much more efficiently versus a very heavy fluid at cold temperatures.
Old Oct 12, 2014 | 06:45 PM
Colorado Sparky's Avatar
Exactly. Mine was always OK with stock and I live in Colorado.
Devesh Budhram
Dec 30, 2016 03:21 PM
oguratevo
11
Aug 31, 2013 11:46 AM
Gqracer
Apr 5, 2013 08:50 AM
Blue Evo 8
12
Mar 4, 2013 11:13 PM
heingtaing
15
Mar 4, 2011 09:12 PM
