new fuel rail necessary with new injectors??
Old Aug 13, 2011 | 08:12 PM
sr20detisbetter's Avatar
^ +1
Old Aug 13, 2011 | 08:14 PM
ch53avitech's Avatar
Originally Posted by vmrevo9
stock rails are pretty stout.
Originally Posted by sr20detisbetter
Yeah I've seen plenty of evos around here running huge injectors on stock rail
+1
No need to run high flow rails. There's plenty 600+hp evo's running 10's and 9's with the stock fuel rail.
Old Aug 13, 2011 | 08:29 PM
Ian0611's Avatar
Originally Posted by ch53avitech
+1
Sounds good! So it doesn't matter if you're on pump gas or E85?
Old Nov 9, 2011 | 04:40 PM
khasal's Avatar
My recently completed project is running the FIC 1100cc high z injectors and the stock fuel rail and walbro pump upgrade. The install and tune were done the same day. put down some solid numbers on the first tune. Approx 380 hp.
Old Feb 9, 2012 | 03:49 AM
superkizuna's Avatar
Okay so, I have already gotten an aftermarket fuel rail in and a FPR to boot. These parts were ordered at the behest of my tuner here in Italy. He said I should get these parts if I was planning on running bigger turbos. I'm not trying to get off pump gas because I actually like to cruise around and drive to work.
I will get bigger injectors but nothing like I've been reading in this post. Can I use the FPR to squeeze extra gas out of stock injectors? Is that dumb? Does the new fuel rail offer any improvement over stock besides looks?
Old Feb 9, 2012 | 05:04 AM
blknblubkrdude's Avatar
Technically the aftermarket fuel rail should increase flow, but unless you are high-HP it is usually not necessary.
The thing I like about the aftermarket fuel rails is the ability to have a test port, or sending unit for a guage plumbed in.
Old Feb 9, 2012 | 06:40 AM
thepoint4life23's Avatar
i think around 600hp is when you want to start looking in to a rail
VWJETTY
Jan 2, 2014 11:55 AM
Smartj90
May 1, 2012 03:29 PM
RaysEvoX
Jun 27, 2009 03:21 AM
Evo8Emperor
Oct 11, 2007 01:23 PM
DSMotorsport
Jan 25, 2006 11:45 AM
