stupid topic
Old Aug 18, 2011 | 01:12 PM
Countrystrong11's Avatar
stupid topic
Ok just got my car back from getting tuned, tuner said he couldnt get my car to boost over 18psi even with the boost controller turned all the way up. My guess is bad waste gate actuator? Anyone else have any input.
I just hit 300whp with intake, turbo back, 272 cams fuel pump and boost controller. A friend has the grimspeed electric boost controller that i am going to ask if he wants to use that insted of my halman.
but im stumped on what it could be
Old Aug 18, 2011 | 01:25 PM
geevolution's Avatar
Did you do a boost leak test before having the car tuned?
Old Aug 18, 2011 | 02:12 PM
Vivid Racing's Avatar
Boost leak
Vaccuum leak
w/g stuck open
weak w/g spring
turbine failure
Blocked exhaust/cats
faulty boost controller
It could be any of those things. Good luck sorting it out. I'd start w/ swapping your boost controller for your friends, since that'd be easy.
yes i did, and replaced the throttle body shaft seals, other than that only a small leak from the map sensor. I need to replace the o2 sensor on the ow housing, caused the tuner to go nuts. made all kinds of weird readings until about an hour of driving. then everything gets normal and reads fine
Old Aug 18, 2011 | 02:55 PM
Originally Posted by Vivid Racing
Boost leak
Vaccuum leak
w/g stuck open
weak w/g spring
turbine failure
Did a boost leak already
cant hear any vacuum leak
Looking for a 18psi actuator
see above
hope no turbine failure
no cats and just put the exhaust on
brand new boost controller from hallman
Old Aug 19, 2011 | 12:16 PM
ok, so i replaced the waste gate actuator that didnt do it.
I pulled the vacuum line off of the actuator nipple and it boosted well over 20, so would that be a bum boost controller?
Old Aug 19, 2011 | 12:48 PM
Kracka's Avatar
Sounds like it, get one designed for higher boost levels.
Old Aug 19, 2011 | 01:45 PM
thedru13's Avatar
What Spring do you have in your MBC? That could be your issue.
Old Aug 19, 2011 | 04:26 PM
Kimposs's Avatar
my boyfriend is having the same issue with his hallman MBC. We tried with the stiff spring and made no difference
Old Aug 19, 2011 | 04:37 PM
housedj's Avatar
here's an evo9 18psi actuator:
http://www.dsrturbo.com/forced-perfo...or-18-psi.html
Old Aug 21, 2011 | 02:57 PM
Ok to keep everyone updated. I replaced the wastegate actuator, still the same thing. I have a new boost controller coming in the mail.
But i also noticed that if i let my car sit for about a day then start it i get some white smoke from the exhaust. If i drive the car it will go away. its only when its cold and warming up.
Coolant level seems good car doesnt get hot. Oil is fresh and full. Changed it 3 or 4 weeks ago and there was no mix of coolant in the oil. The turbo still spools fine right up to 18 then brick walls there. If i pull the line off the wastegate it will boost over 20 with no problem. So i dont think its the turbo.
Im running a catless turbo back if that has anything to do with it. i will be replacing the front 02 sensor as well as soon as it comes in...told that was causing my air/fuel to go all crazy like i am seeing.
Old Aug 25, 2011 | 09:49 PM
Ok so tonight i added my grimmspeed MBC, ebay o2 housing, new o2 sensor, new wastegate actuator, and front motor mount for shats and giggles... as soon as i get the donut gasket for the downpipe i can throw it all back together and give it a test drive and hopefully i can build over 18psi. And my wide band reading will be normal again.
Old Aug 25, 2011 | 11:02 PM
svt_lightning01's Avatar
what about the pre load on the WG? i went down that road once upon a time.
Old Aug 25, 2011 | 11:21 PM
with the old wastegate i had it adjusted all the way in. Have not messed with this other one yet. i will see what happens when i get it back together and test it.
Old Aug 26, 2011 | 04:31 PM
I GOT MY BOOST BACK!!!!!! Just need to get a retune. When i was driving it i got a code for P0172 System to rich bank 1.
Now i can get it tuned for over 20lbs of boost.
