Did I just get incredibly lucky...?
Old Sep 1, 2011 | 06:08 PM
  #31
AlphaRemix's Avatar
Originally Posted by cmspaz
If you're still running without knock, you're fine.
A guy at work took one of the Ranger delivery trucks through a puddle at speed, hydrolocked the motor and not only bent every rod, but one snapped and went through the oil pan. If your light went under, so did your air filter. Consider yourself extremely lucky.
That's the thing, I know never to take a puddle at speed for that exact reason. I literally inched my way through most of it. As for the no knock, I'm told depending on how badly a connecting rod is bent, it may not necessarily knock so I don't believe I'm 100% in the clear just yet.
Originally Posted by fwd_josh
you probably just got some water in a few connectors, causing them to through a few codes and the car to run like ****. as you drove the water dripped out and it started to run better. i would change the oil to make sure it isn't milky. and check the trans fluid as well. if that's what happened, you should play the lottery later on.
Just changed the oil yesterday, no milky consistency or anything even remotely resembling that. It looked like normal used engine oil which I guess means water, if any, did not make it past the rings.
Originally Posted by __pg
I had a similar event happen to me. Driving in some pretty harsh rain on the interested I approached an area I knew flooded pretty quickly, I slowed up. After driving through the smallish puddle I accelerated and my car bogged and had no power. I was having problems with my upper ICP pipe surging off my throttle body so I just assumed it was that. I pulled over, grab a screwdriver and an umbrella. Popped the hood and everything was in place, mild case of the freak outs set in. Got back in the car and it started but it was not happy, bogging and cutting. I limped it to a parking garage and let it sit/dry for a few hours. Drove home fine and haven't had a problem since.
My car is 100% stock, never installed an aftermarket IC or piping.
Originally Posted by SavEVOIX
I've had the same exact issues you are claiming. I promptly took my vehicle home and changed the oil immediately due to slight milkyness and my car ran perfectly with no codes thrown.
My oil came out normal, looked like typical used engine oil. Unlike you though, I did throw some codes. I cleared them however and they have yet to come back.
Originally Posted by Pssst
OP, I had the SAME problem sunday when driving home from my buddies lake house... there was no other road open and the one that was... had a small section of flooded road... and saw multiple cars driving through it fine... so I took their same path and my car died and coasted out of the water....
Instantly freaking out...started up... ran like crap.. .died... started it agian and tried to drive.. it died...
Then I went into mechanic mode, called a buddy for some ideas, he helped BIG time for this...
I always carry a Navy handyman bag filled with tools to do just about everything to a car in my trunk... so I busted that out... took off the MAF dried it as best I could with some Microfiber towels I kept in my car... managed to dry it pretty nice, but the intake cone was still pretty damp. dried the intake pipe as best I could..
proceeded to try and start the car and it started to crank... So I put my foot to the floor( to kill the injectors) and the car started RIGHT UP... ran like crap for 5minutes or so... was probably recorrecting itself after the water issue... Vacuum went back to normal and the 02 readings went back to normal... so I was good to go... boosting was funky because the MAF wasnt 100% dry but it certainly got me all the way home (90 miles)
we both lucked out
As the post above me... I'm changing the oil tonight for this exact reason!
Yeah, this was the theory that my buddy who is a bit more mechanically inclined than me had. He thinks I probably wet the MAF enough to cause it to stall out and throw erratic codes. After driving it for awhile, it dried out and things normalized (this is best case scenario and I'm not holding my breath). Did you get any CELs through it all? I threw 3, cleared them, and they've yet to come back. So far I've driven about 150-200 miles since the incident and no issues. But, from my research it would seem a bent connecting rod, depending on how severly it's bent, may not manifest itself to be a problem right away.
My compression tester should arrive tomorrow, so I'll run that over the weekend. Though again, if a connecting rod isn't bent too heavily, a compression test might not show anything at all.
Old Sep 1, 2011 | 06:56 PM
  #32
Pssst's Avatar
I got a CEL initially when it happened but once drying the the MAF they all went away... literally instantly... I was worried about the bent connecting rod too ;( but from everyone that I told they told me it takes a lot of water to have that happen... and I know there wasnt a LOT that got in there...
I've driven almost 400 miles since it happened and haven't noticed any differences... I should probably get my car compression tested just to be safe.... if a rods bent... I'm doing a forged bottom end for sure Looking forward to hearing your results since your situation sounds exactly the same as mine.
Old Sep 2, 2011 | 12:29 AM
  #33
17pstockcar's Avatar
I would change all the oils, motor, diffs, ayc everything then all have breathers that can leek water into the system. It might be 3000miles before it shows the damage.
I would pull the intake and excaust and see how far the water made it in but its proberley to late for that to show.
Very lucky tho in many ways
Old Sep 2, 2011 | 12:37 AM
  #34
mirkendargen's Avatar
Thinking about it, you would have to suck in a LOT of water for large amounts to make it into the engine. You'd have to fill the IC and all the piping, unlike a NA engine with a relatively short and direct intake pipe. You guys might want to take your intercoolers off and make sure they aren't half full of water or anything
Old Sep 2, 2011 | 01:29 AM
  #35
PaEvo's Avatar
Once upon a time, my gf at the time was driving her rsx through ocean city MD and it stated to downpour. as a side note, she had a aem cai, and no bypass filter (supposed to keep water out of engine), the filter sits in the fender well about a foot off the ground. if you have ever had the privilidge of being on the city streets of ocean city MD during a heavy rain, you know that the streets do not drain. They just kinda flood. anyway my gf went drove through a big puddle not even a foot deep and the car sputtered and stalled. totally dead, it wouldnt turn over and needed to be towed.
long story short, the next morning a mechanic pulled the plugs, wiped them dry, changed the oil, put a new oil filter on, and it fired up.
so it should be obvious from my comment and other posts that if your car reacted negatively, you can assume that at some point water got into the engine. you got super lucky that it wasnt enough water to douse the plugs or dilute the gas.
at the very least, change the oil, and use a new filter. also, i would take off the intake filter and look into the intake track and make sure that there is no water residue hanging out
Old Sep 2, 2011 | 01:34 AM
  #36
gymnasty's Avatar
sounds like you got very lucky sir! now go buy some lotto tickets and dont EVER do this again
Old Sep 2, 2011 | 01:50 AM
  #37
MR. EVO MR's Avatar
Didn't read everyones post, I'd change the oil to be safe.
Old Sep 2, 2011 | 05:43 AM
  #38
FresHsincE85's Avatar
If I were you I would head to the nearest conrner store and scoop up some lotto tickets. Cuz you got luck on your side.
Edit: didnt see 2 posts above me....FAIL. lol
Old Sep 2, 2011 | 07:33 AM
  #39
AlphaRemix's Avatar
Did all of that, I know water can creep in through the diff/xfer case breather holes and the car was for sure submerged at their heigh for awhile. To reiterate what I said in an earlier post, engine oil came back clean - as in no milky consistency indicating water contamination. The diff fluids were fine, with the xfer case one being dirtier than the rear, but that's always the case. Also, no signs of water contamination.
I'm not completely sure that's true...
What your gf experienced was true hydrolock. In that situation, the car will never turn over until you pull the plugs and remove all the water from the cylinders. Often times when it is that severe, a connecting rod and other internals have almost positively been damaged. Just out of curiosity, how long ago was that and is her RSX still on the road with no problems?
Also for those of you who have been waiting in anticipation of my compression test results (/sarcasm) they came out to be:
140-150-150-140
At first I thought that was low, until I realized the compression test FAQ/How-To is from the VIII service manual. And that's when I found...
"From Evo 9 service manual:
Cylinder Compression:
Crank the engine with the throttle valve fully open and measure the compression pressure.
Standard value (at engine speed of 250 r/min): 1,000 kPa (145 psi)
Minimum limit (at engine speed of 250 r/min): 637 kPa (92 psi)
Measure the compression pressure for all the cylinders, and check that the pressure differences of the cylinders are below the limit.
Limit: 98 kPa (14 psi)
Evo 8 standard from the manual is 164 psi, but I have done a ton of them and they are usually 170+
Most of the 9's I have done are 135-145
That was a quote I copy and pasted, but forgot to get the author's name. If someone knows who this is please tell me and I'll credit you. Further investigation showed that the IXs indeed do run a lower compression than the VIIIs so for anyone with a IX that thinks their compression is low, STOP REFERENCING VIII motor specs! But anyhow looks like the motor is actually in tip top shape, at least compression wise! So my hopes are a little higher.
Old Sep 3, 2011 | 10:23 PM
  #40
PaEvo's Avatar
well, after the mechanic pull plugs wiped them down, changed oil and filter, it turned over no prob and smoked for like 15 minutes.
car never had any further problems. i was super surprised that nothing cracked in the block. considering engine internals being a nice warm 200+ deg. F, and then getting a nice cool drink of 60 deg. water, i was amazed nothing cracked.
that said, she is no longer my gf, so maybe the rsx had a short life after that
Old Sep 4, 2011 | 10:58 AM
  #41
B.Prug87's Avatar
sounds like you got lucky
Old Sep 4, 2011 | 11:23 PM
  #42
vboy720's Avatar
glad to hear you made it out safe.
Old Sep 7, 2011 | 08:08 AM
  #43
AlphaRemix's Avatar
The smoke could have been carbon buildup. If she only sucked in a very very minor amount it would have the equivalent effect of seafoaming your engine to get the carbon buildup out. And I know firsthand coming from a 1G DSM that seafoaming a dirty motor will seriously top any tire burnout haha.
That being said, thanks to all the well wishers in the thread! If everything holds, this should be my last bump to this thread (fingers crossed).
As a side note, if anyone were to have the misfortune of having this happen to them, the best advice I can give is....CALL YOUR INSURANCE COMPANY! Hydrolock or damage as a result of it is covered if you have comprehensive in your policy. It is considered flood damage. I've read a few stories where some 'street brand' carriers try to weasel their way out of it, but if you're with one of the Big 5 you shouldn't have a problem. I have Progressive and they not only assured me it was covered, the claim is valid for SIX YEARS.
Old Sep 7, 2011 | 08:14 PM
  #44
I've actually heard of people using a power washer to spray a very small stream of water into a vacuum tube to clean similar to Seafoaming. The water instantly boiling breaks down the buildup. The claim was that it was actually better than Seafoaming because it isn't a caustic solvent like Seafoam. How true that is, idk...
Old Sep 10, 2011 | 08:20 PM
  #45
kmvguy83's Avatar
Wow lol
