Fluid Change Help Plz
Well guys,
I havn't changed the trans/tcase/diff fluid since 30kmiles when I did my clutch job.....Well now im pushing the 56k mark and shifting is getting a little notchy so I think its time for another fluid change. Could someone please chime in on the weight for the tran/tcase/reardiff for a 2006 Evo 9 MR. Something I can pick up at the local store. Ill prob run royal purple since the availability. PLZ HELP !!!
my 06 has about 90000 miles on it, my motor only with about 4000. But Mitsubishi recommended that i drain and refill my transfer case, transmission, and differentials soon. Transmission after 60,000 miles, diffs between 30k nd 60k , and id agree with eddievo8 about the transfer case.
http://www.lancershop.com/customer/p...cat=198&page=1
It's 90W in any case. Amsoil severe gear 75w-90 if you can get it locally for TC and Rear diff.
Trans, since it is a 6 spd, people rec the BG stuff.
I recommend checking the fluids sticky at the top of one of these forums. MANY (if not ALL) of the sales websites have the incorrect fluids listed for the incorrect parts.
I just did all the fluids on my 9MR using OEM. I got them from Mellon and Lancershop, but as I said, I checked here first to see which fluid was for which.
I had to use heat to get my fill bolts to break loose.
