P0304 Cylinder Misfire Help!
Old Sep 6, 2011 | 01:32 PM
5LEEPERISAH23I's Avatar
ok so i just converted to E85. I have a Single 255 walbro fuel pump and just added FIC 1550cc injectors.
I get this code when starting up my car just about every other time. It reads P0304 "Cylinder 4 Misfire." This is what i dont get tho. It never misfires, idles perfect, starts up perfect drives perfect and a/f cruising is 14.2-15.2 so perfect also
but when i go WOT it leans out to like 14.7-16.0 A/F
the only thing i changed was the injectors and the tune has been scaled for theses injectors.
My idea's about the problem: injector 4 is bad, something just got stuck in the Fuel Pump while running so low on gas while converting over to E85, ECU thinks somthing is wrong just becuase im running 4x's the size injector as stock, Maybe injectors are not scaled right in the tune but really doubt that.
What do you guys think the problem is?
Old Sep 6, 2011 | 05:18 PM
4RETECH's Avatar
Easy thing to do is swap the injector to another cylinder and see if the code moves.
And as for your tune, it's way to lean at wot
Old Sep 6, 2011 | 05:28 PM
i just did that. No code has came up yet.. i swapped cyl 4 n cyl 2 so far no CEL
Enjoi926
May 31, 2017 06:47 PM
mikes3kgt
Aug 23, 2014 04:33 PM
sofly1990
16
Oct 21, 2013 08:16 AM
Arkitek
18
Jun 27, 2010 06:53 AM
weebles
12
Mar 16, 2010 04:28 PM
