alternator not charging with stock gauge removed in evo 8
Old Sep 10, 2011 | 10:29 AM
evodziobak's Avatar
Does anybody know what needs to be done to have the alternator charge the battery without the stock gauge unit installed? After I take out the gauge the alternator no longer charges the battery. I'm installing the AIM MXL dash and need to get that worked out.
Old Oct 10, 2011 | 05:08 PM
bwk's Avatar
bwk
Just got my Pista and having the same problem. Let me know if you get this resolved.
Old Oct 11, 2011 | 01:10 AM
evodziobak's Avatar
yes I got it figured out. One way to do it is to put a 39 ohm 5 Watt resistor or a 100 ohm 5 Watt resistor between pins 9 and 19 of the C-01 plug that normally plugs into the stock gauges. Instead of a resistor you can also use just a regular 12V 5W bulb but I think the resistor solution is better because if the bulb burns then you'll have no connection between the pins and the alternator won't start. But that's for an evo 8. I'm not sure if the pins are the same for evo 9. I'll try to find out about the pins on an evo 9 and let you know.
Old Oct 11, 2011 | 09:44 AM
ProPilot04's Avatar
Wth! So... if one of my gauge cluster bulbs burns out, my alternator will stop charging?
Old Oct 11, 2011 | 01:19 PM
warstang27's Avatar
lol no they're backdooring the connection for the gauge cluster to believe its connected still because theyre using an aftermarket gauge cluster. if your gauge lights go out your alternator will still work. my speedo and gas/eng temp ones went out and the alternator still worked fine.
Old Oct 11, 2011 | 01:33 PM
evodziobak's Avatar
No, that's not going to be the case. Your stock gauge cluster aside of the bulb indicating that the alternator started charging must have a resistor that is actually responsible for starting the alternator. So if the bulb burns the the alternator will still start charging. I did a test, taking out the alternator bulb out of the stock gauge cluster and the alternator would start charging normally. I just had to have the gauge cluster connected. Without the gauge connected the alternator would not start charging. Just like warstang27 said I needed to find a way to start the alternator without the stock gauge cluster connected because I am using an aftermarket digital gauge.
Old Oct 11, 2011 | 07:42 PM
bwk's Avatar
bwk
ya I saw that to use 9 and 19 on the plug with a bulb. Problem is 9 and 19 are empty even though the wiring diagram shows that bulb and resistor there for the EVO9
Old Oct 12, 2011 | 12:49 AM
evodziobak's Avatar
You might just be looking at the wrong plug or counting the pins from the wrong side. Make sure you're looking at the C-01 plug not the C-02. At first I did a mistake like that, counting the pins from the wrong side of the plug and just like you said they were empty.
Old Oct 13, 2011 | 09:06 PM
bwk's Avatar
bwk
Sorted it out! I just used a 12v led bulb
Old Aug 7, 2012 | 11:57 AM
moevo8eghatch's Avatar
okay im having the same problem in my evo. the alternator is giving 12.4v only my battery is new. new mitsubishi alternator. ran extra grounding, checked the posiive wire. ad still doing the same., i even tried the bulb thing and still didnt work, i have aem ecu if that would matter. please lmk what could be the problem
Old Aug 7, 2012 | 07:35 PM
ExViTermini's Avatar
Check the field wire to see what the voltage input to the alt is.
Old Aug 12, 2012 | 05:52 PM
its showing 12.4/. i also tested the alternator directly from th positive nut. showed the same thing
Old Sep 11, 2014 | 06:00 PM
Ryan Amini's Avatar
sorry to bring back an old thread but im having a similar issue with my Evo 9... I have the volt gauge removed and having alternator issues now :\ Does someone have a diagram so I can wire back in Volt gauge how it was? Or any sort of fix... It would be much appreciated.
Old Dec 15, 2014 | 08:27 PM
evolvedevo91's Avatar
Wow this thread just saved me a huge headach . Thanks op
Old Apr 11, 2021 | 04:32 PM
Chrispy0530's Avatar
Necro-revive.. but this thread saved me. I had my Evo all apart this weekend to cleanup / remove a bunch of cables that aren't being used anymore. When starting to put stuff back together, I noticed the alternator wasn't charging. Thought I pulled something that was needed. Started plugging literally everything back in that I took out.. long story short.. I didn't plug the gauge cluster back in!!! I read this thread and omg.. Had no idea it was required to have the alternator charge.
steve-o411
12
Jun 26, 2014 04:31 AM
fafaforza
Jan 7, 2013 11:04 PM
03_Lancer_ES
Lancer Troubleshooting
10
Jun 10, 2009 12:29 PM
joshakaja
Feb 16, 2009 12:03 PM
