Squeaky Recaros?
Old Jan 4, 2004 | 02:07 PM
Lightsped's Avatar
Question Squeaky Recaros?
Anyone here experiencing squeaky Recaros?
My driver seat squeaks when I go around turns at a higher than normal pace. The squeak sounds as if it is coming from the area where the seat back, meets the bottom part of the seat.
Its not a big deal really, just curious if anyone else has this, and if there is a simple solution? If I knew exactly where to spray WD40 I would, but I am not certain exactly what is causing the squeak.
Old Jan 4, 2004 | 02:25 PM
favre95's Avatar
it is not the seat...I had this problem in my talon too...it is the seat belt assembly...the clips that is that is mounted next to the console. But yes I have it now and had it in my last mitsu product...may just wanna sray a very small amount of a good lube in there....not much at all though...seems to help.
Old Jan 4, 2004 | 02:52 PM
MrBonus's Avatar
I have this problem if I lean over towards the passenger seat while driving.
Old Jan 4, 2004 | 03:01 PM
Daveyd's Avatar
Same problem here...seems to squeak when I shift my weight around
Old Jan 4, 2004 | 03:17 PM
webguy330i's Avatar
Squeaky as hell, but I got over it 9000 miles ago.
Old Jan 4, 2004 | 03:23 PM
sleet's Avatar
Yeah i've had them squeak, very annoying.
Old Jan 4, 2004 | 04:20 PM
Stock's Avatar
Mine make so much noise i drives me nutz
are any of you fat cause i figured it was my fat *** that is making them squeak
6,1 265lbs
Old Jan 4, 2004 | 04:28 PM
Lightsped's Avatar
Around 155-160 lbs here.
So has anyone attempted to lubricate the area causing the squeak?
Is it the seatbelt assembly? I am not clear on exactly what part of the seatbelt would cause the squeak. It sure sounds like it is the seats to me....
Old Jan 4, 2004 | 04:30 PM
matt55's Avatar
yea my SEATS squeak too
Old Jan 4, 2004 | 04:55 PM
Dale_K's Avatar
My driver's seat squeaks somewhere near the adjuster mechanism. To be fair, I'm a really big guy - 300 lbs, so the seat really has it's work cut out. My other car seats don't squeak however. I sprayed the area with some silicone and it helped but the squeak came back after a couple weeks.
Old Jan 4, 2004 | 05:11 PM
Czubaka's Avatar
Mine started shortly after I bought it. Plus, somewhere around the drivers side B-pillar or front/rear door panels I'm getting some noisy creaking that I can't pin down.
Old Jan 4, 2004 | 05:31 PM
Trbo Dad's Avatar
Spray some silicone spray into the hinge where the back/bottom of the seat meet = problem solved.
Old Jan 4, 2004 | 06:11 PM
M3lachsilber's Avatar
choad
That sucks that yers squeek!! Fat ****ers..
JK..
My seats have been quiet as hell..
The lube or WD40 suggestion I would think would help..
Good Luck!
Old Jan 5, 2004 | 04:47 AM
Lightsped's Avatar
With the seatback fully laid back, do you recommend spraying the hinges from the top (near cushions), or from the bottom (near the plastic shell)? Also, are the hinges easy to get too with the seat back fully laid back?
Old Jan 5, 2004 | 06:15 AM
Trbo Dad's Avatar
spray from the top down. it's really not too difficult.
