heat wrap o2 housing?
Old Sep 16, 2011 | 09:11 AM
Locdizzel's Avatar
Just had a megan manifold that i got years ago (i know its not the greatest choice), re-welded, braces added, coated from a friend for a bottle of rum . I wrapped in DEI titanium and wondering if i should wrap the o2 housing as well, i've heard good and bad things about wrapping o2 housings-reduce engine heat, increase spool, but kill o2 sensor faster?
i still have have about 10ft left so im thinking of doing upper rad hose and down pipe anything else to wrap?
Old Sep 16, 2011 | 09:20 AM
Macaroni's Avatar
I've never heard of the o2 sensor failing because of heatwrapping but you never know. I have my mani wrapped too and will buy more soon to wrap the downpipe, o2 dump, and probably intake as well.
Old Sep 16, 2011 | 11:30 PM
EvoJoeIX's Avatar
I wouldnt heat wrap anything on a car that you drive in the rain or snow...
And i would love to know how heat wrapping a o2 housing increases spool...
Old Sep 16, 2011 | 11:34 PM
DubsE46's Avatar
Wondering the same thing, will it really improve spool and how? How much cooler will it be compared too no heat wrap?
Old Sep 16, 2011 | 11:38 PM
EvoJoeIX's Avatar
I was being sarcastic, no way will it improve spool at all.
If your worried about under hood temps, send your o2 housing, manifold and turbo hotside to swain tech coating
Old Sep 16, 2011 | 11:41 PM
DubsE46's Avatar
Yeah that's what I figured haha^^
Just asked since I haven't looked into the pros and cons of heat wrapping stuff
Old Sep 17, 2011 | 09:37 AM
Mikey@Spec-Ops's Avatar
Who cares about the 02 housing! You just made the Megan header a BOMB! With the coating and the wrap, that batch is going to get so hot it will crack so bad you could prob stick your finger in the damn thing. I would take the wrap on the manifold brother!
Mikey
Old Sep 17, 2011 | 09:42 AM
EvoJoeIX's Avatar
I would just save your time and get rid of the megan manifold, its made of cheap thin metal, even its it was re welded, its still junk. Save your time and get a ported stock manifold.
Old Sep 17, 2011 | 10:27 AM
awdordie's Avatar
I've read somewhere that heat wrapping a manifold can increase spool due to thermal dynamics or some crazy ****. Im not sure if its true but ill look for the article and post it if I find it.
I agree about the coating AND heat wrap on the megan. You might wanna get another manifold cuz like stated that's going to crack again so bad it may just fall off going down the road.
Old Sep 18, 2011 | 06:49 AM
Locdizzel's Avatar
i read it would increase spool somewhere on dsm forum, but ill just have my stock one ported and use this as a back up till i get it back, thanx for the info
Old Sep 18, 2011 | 05:55 PM
TommiM's Avatar
here is another option to keeping heat away from other components... http://www.turblown.net/store/index.php?productID=79
Old Sep 18, 2011 | 10:59 PM
ddsboytoy's Avatar
That header is going to get alot of stress cracks
Old Sep 18, 2011 | 11:01 PM
EvoJoeIX's Avatar
Thats the same stuff we use to inside the thrust reverser on a jet engine to keep the heat in. Very good stuff, but not cheap
Old Sep 19, 2011 | 05:41 AM
chu's Avatar
chu
I wrapped my manifold and downpipe for heat control purposes. I don't know about how much spool one would acutalyl get from wrapping, but the theory in thermodynamics is that exhaust gases will move faster if its stays hotter. My guess is not enough to make a difference in spool. For me, its more of a concern to to keep heat away from my intake, and away form the oilpan in the area of the downpipe.
Old Sep 21, 2011 | 08:25 PM
reboundicon's Avatar
There are benefits to heat wrapping such as the exhaust fumes exiting quicker, but I wouldn't do it to your o2 housing. I considered it for my downpipe, but heard stories of them cracking under the extreme heat and I would rather not have to worry about oil dripping on it and potentially causing any harm.
