smoking catch can?
Old Sep 23, 2011 | 12:19 PM
bnr34rb26dett's Avatar
smoking catch can?
so i have a build 2 liter running fp black and its losing oil all the time.
i noticed the other day that my catch can thats attached to back of the valve cover and on the side is smoking.
in another words, oil was burning inside the catch can.
is this normal? am i getting excess loss of oil? i do go through a quart of oil about every 5th gas fill up
Old Sep 24, 2011 | 07:05 AM
buuuump
Old Sep 24, 2011 | 07:21 AM
wizzo 8's Avatar
That smoke is normal with any engine. If you take the oil cap off of any hot engine you will see that smoke. Built motors consume more oil than normal engines. Some more than others. If its more than 1qt per 1000 miles then thats probably a little excessive. Do a compression test to see how healthy the motor is.
Old Sep 24, 2011 | 07:58 AM
peanutjoe's Avatar
u have a leak. get rite of it.
Old Sep 24, 2011 | 09:50 AM
studioface's Avatar
Are you burning oil? do you have any blue smoke from exhaust? do a compression test and see where you stand your turbo can also be leaking oil through its seals.
Old Sep 24, 2011 | 10:58 AM
yea but im pushing 32 psi on fp black.
no blue smoke ill check on seals
Old Sep 24, 2011 | 11:00 AM
wizzo 8's Avatar
Do a compression test. If its good then the smoke or steam is normal.
Old Oct 16, 2011 | 12:10 AM
jessmanEVO's Avatar
What would happen if there was slight amounts of smoke out of the exhaust?
Old Oct 16, 2011 | 05:02 AM
wizzo 8's Avatar
If you are sure its smoke and not condensation from being cold then that's not good. Blueish smoke means you are burning oil. Black smoke means your engine is running too rich or dumping too much fuel.
Old Oct 16, 2011 | 05:55 PM
jessmanEVO's Avatar
Sorry, I wasn't clear enough. I meant to ask, what if there was smoke coming out of the exhaust AFTER a hard pull in a gear. Not during.
Old Oct 16, 2011 | 06:00 PM
EvoDom's Avatar
After a ill is blow by. Either rings or bad valve seals.
Old Oct 16, 2011 | 09:29 PM
novem's Avatar
Did you break in the engine when you got it back? Or did you start racing around after you got it back? I would do a running compression test and see what you get. That's a lot of oil loss.
N
Old Oct 17, 2011 | 02:03 AM
jessmanEVO's Avatar
Broke it in on the dyno. I doubt its bad rings or seals because i dont see any residue on the rear bumper. In addition, oil consumption is very low.
Old Nov 27, 2011 | 02:45 PM
Evo3573's Avatar
I'm having similar issue I think it may be my turbo
Old Nov 27, 2011 | 02:55 PM
3wd's Avatar
3wd
I would do a leak down test on your engine. That can also narrow down what might be the cause, if any, where the smoke is coming from.
