Which boost control?
Old Sep 26, 2011 | 09:55 PM
Evo45's Avatar
I'm deciding between hallman pro manual boost control or Grimmspeed 3-port electronic Boost Control solenoid.
Old Sep 26, 2011 | 10:06 PM
asu11's Avatar
Main thing you need to know is that with the grimmspeed youll need to access the ecu to make any boost changes.
Old Sep 26, 2011 | 11:01 PM
Evo45's Avatar
Yes well aware I have to. Ill be sending in my ecu to get reflashed. Thats y i kinda whanted to see which way to go. In the cold weather would I have to tune to a lower boost or it should adjust itself?
Old Sep 27, 2011 | 06:10 AM
evo8426's Avatar
Don't send your ecu anywhere. Get a real tune, not some off the shelf bs tune that is crap.
Old Sep 27, 2011 | 05:29 PM
Evo45's Avatar
Where I'm at there's no tune shop that works on evos. So I was going to send it to Dyno flash I read some good reviews. I would do it but I don't want to mess my car up
Old Sep 27, 2011 | 05:54 PM
evo8426's Avatar
Dynoflash will mess your car up. You must not be reading reviews on evolutionm if you are finding "good reviews". But like I said in the past to other members, get yourself a tactrix cable and evoscan and have a remote tuner send you a map
Old Sep 27, 2011 | 05:59 PM
David Buschur's Avatar
Dynoflash won't mess your car up.............he's tuned thousands of EVO's.
I would also recommend getting a cable though and probably using Mellon or some others.
Old Sep 27, 2011 | 06:51 PM
Evo45's Avatar
Around how much do maps cost? What about a cobb ap?
Old Sep 27, 2011 | 07:06 PM
s.lamoureux's Avatar
if you can't bring it to a shop and get tuned don't just buy a generic map. Get a tactrix cable and send it to a tuner, that way you can log your resluts with evoscan and send it back and forth until you have the tune dialed in.
Old Sep 27, 2011 | 07:07 PM
also doing it that way you could use the grimmspeed and have each gear tuned individually.
Old Sep 27, 2011 | 07:12 PM
Evo45's Avatar
Which tuner u guys recommend?
Old Sep 27, 2011 | 07:26 PM
forc3 f3d's Avatar
mellon or tscomp... cant go wrong with either one.
Old Sep 27, 2011 | 07:29 PM
BLK_EvIL's Avatar
+1 get a cable and do a e-mail tune (remote tune) thers a few tuners that do them pretty cheap also. I ran a dynoflash mail in tune wene i first got my evo it wasnt horrible but it was a block tune and night and day diffrence between a custom tune.
Old Sep 27, 2011 | 07:39 PM
Evo45's Avatar
K it's settled then I'll get a Tactrix cable and evo scan. Is Jestr tuning good?
Old Sep 27, 2011 | 07:45 PM
Evo45's Avatar
One more thing do I need a wideband
