what to do what to do!?!
Old Sep 30, 2011 | 05:39 PM
brunz44's Avatar
looking to spend about 2gs on some new parts not the biggest car tech witch is why im posting i have a evo 8 hks 264/264 n cam gears studded ported and polishedhead hks intake pipe arc intake hks ssqs bov recirculated greddy front mount and exedyv6 puck st 3 clutch + lightwieght flywheel was thinking new turbo injectors and fuel pump but im lookin for opinons thanks
Old Sep 30, 2011 | 05:45 PM
brunz44's Avatar
P.s. lookin for biggest hp gains as my dd
Old Sep 30, 2011 | 05:46 PM
binky's Avatar
Definitely do the fuel pump first.
For 2G's to spend, you will be looking at a used stock framed turbo, such as an older FP Green. Depending on the power you want to make and the fuel you will be running, you will probably need to upgrade your injectors. FIC 1050's with a Walbro 255 should do you just fine.
However, with all of that you might be around or just over 2 grand. At least 1200-1500 for the turbo - 350 for the injectors and 125 for the fuel pump and install kit.
-Bink
Old Sep 30, 2011 | 06:05 PM
1UpMoto's Avatar
Im sure you would pick up some decent power if you got rid of those cams and went with better ones.
Old Sep 30, 2011 | 07:11 PM
brunz44's Avatar
-Bink
Thats pretty much what i was lookin to do now - gunna have the car tuned on 93 hopin for high 300 low 400s
