new install question..need help!
Old Sep 30, 2011 | 10:46 PM
babaz7's Avatar
ok so im upgrading my cams from stock to gsc s2's and also adding supertech dual valve springs and retainers on a stock head, will this work fine or do i need anything else besides this?
Old Oct 1, 2011 | 07:16 AM
babaz7's Avatar
anyone? im doing this tomorrow so i need some feedback, show some love people.
Old Oct 1, 2011 | 07:22 AM
evo 9 guy's Avatar
Coolant, oil, new headgasket, better headstuds, valve cover gasket to name a few
Old Oct 1, 2011 | 08:12 AM
babaz7's Avatar
yea i have all these, but do i need to do anything to the head? do i need to port anything or the cams,springs and retainers will just fit perfectly?
and thanks for the reply.
Old Oct 1, 2011 | 09:03 AM
evo8426's Avatar
Why? My head was never pulled to replace the valve springs. If the head is staying on the car then don't bother with those parts
Old Oct 1, 2011 | 09:13 AM
1UpMoto's Avatar
You NEED the smaller supertech valve stem seals for the dual springs. If you use the oem sized ones they will get pulled up and leak. Ask me how I know lol. Also if you are doing them on the car this tool works amazing
http://www.euroexportinc.com/store/m...ompressor.html
Old Oct 1, 2011 | 01:20 PM
GGevo921's Avatar
Def do the headstuds still even if your not pulling the head. you can still do those, especially if you plan on turning up the boost. lets us know how you like the cams and how much power the car picks up. Good luck, not the most fun job in the world.
Old Oct 1, 2011 | 03:48 PM
evo8426's Avatar
Totally untrue, there are many members on this site that recommend against changing the stock head bolts. Several have ran 30+psi and have had no problem whatsoever since it is knock that causes the head to lift.
Old Oct 1, 2011 | 04:24 PM
gsrboi80's Avatar
Def do the headstuds still even if your not pulling the head. you can still do those, especially if you plan on turning up the boost. .
You couldn't pay me to do headstuds 1x1.
High cylinder pressure will cause a head to lift knock not being the only cause, so yes pre detonation, too much timing advance, and high boost pressure can all contribute to "lifting the head". It's all in the tune
Though I agree there is really no sense on doing headstuds till you really start pushing it and at that point it's probably build time anyway
Old Oct 1, 2011 | 10:53 PM
babaz7's Avatar
im running a gt35r turbo and when i do these mods im planning to run at 28-32 psi, should i do the head studs or not? and what should be a safe rev range,can i take it to 9000 rpms?
Old Oct 2, 2011 | 07:14 PM
divine_evo's Avatar
don't forget to bleed the lifters.
