greddy type s question
Old Oct 1, 2011 | 06:03 AM
4wheelsqueal's Avatar
Purchased a greddy type s bov for one of my galant vr4's before I had my evo. Was told the bov had the evo single-spring mod done to it. Besically its just removing the inner spring because with both in, the evo has a tendency to kill at times? Went to the website he linked me to to check it out and it seems to make sense but what to verify this is a real problem with these bov's . Has anyone on here had to do this mod to make their car idle at all times? If this mod necessary? Thanks for any info!
Old Oct 1, 2011 | 06:33 AM
EVO8emUp's Avatar
The real problem would be venting it to atmosphere. That's why it stalls.
Old Oct 1, 2011 | 07:22 AM
Not doing that! I know better than that to try that on a stock set-up.
Old Oct 1, 2011 | 07:54 AM
bluebanana23's Avatar
I recirculated and would still stall with both springs in. Very dangerous since the car would always stall with the car moving at a high rate of speed.
Old Oct 1, 2011 | 12:10 PM
limp_noodle's Avatar
I was stalling with both springs in and recirculated. I did the single spring mod and adjusted the set screw. The car drives perfectly with no stalling.
Old Oct 1, 2011 | 12:23 PM
Good information, guys! Thanks much! Limp noodle, how far out did you adjust the set screw? Approximately how many turns would you say?
Old Apr 8, 2012 | 06:15 AM
boostnMA's Avatar
I've had the type s for a year now and it never sounded off correctly, it sounded like the stock at anything over 5psi, and it would sometimes compressor surge. I t'd off the boost controller line (turbo to boost controller) and hooked up a 1/8 in line from the t to the bottom port on the type s, and it sounded off perfectly even at high boost (top set screw is set to 6 threads). Also both springs are inside.
It was then leaking under boost, wouldn't hold over 15 and would taper down to 12. During a boost leak test it would open as well, so I took it apart (super easy just make sure you hold down the purple cap when removing the allen head bolts). I noticed that the diaphragm (black rubber piece) was ripped so I took some black rtv and coated the inside of the rip and the outside (the metal circle piece inside the diaphragm comes out). I let it dry for 24 hours (full cure time) then re-assembled it. I also cleaned/polished the inside of the bov and put a thin coat of oil on the shaft. Now it holds boost and sounds off perfectly!
To summarize:
1. T off the turbo to boost controller line and connect the lower port of the type s to the T.
2. Open the BOV and see if the diaphragm is ripped,
- you can try and repair it with
RTV http://forums.vwvortex.com/showthrea...usted-diafragm
-or buy a new diaphragm for $80. http://www.shopgreddy.com/turbocharg...placement.html
3. Clean the inside of the bov
4. Reassemble the bov (keep both springs)
5. Try setting the adjustment screw to 6 threads sticking out from the top of the nut.
Old Apr 8, 2012 | 07:09 AM
vinNybXx's Avatar
I just got rid of my type S on my evo, i had no clueee how much that thing was leaking untill i pressure tested and swapped bovs. I changed it for a APS (highly reccomended) the car feelss sooooo much better spools much faster, betwee. Shifts feel way more crisp, and def picked up the power i was supposed to have. I reccomend getting a new bov asap
