Hood vent/grill removal
Old Oct 6, 2011 | 02:04 AM
BOOSTINAT30PSI's Avatar
Hey everyone. Ive been searching for a way to remove the hood vent and grill off a hood, and to replace them on another hood. Can someone explain how to do it? I searched a bit on the "how to" section... However... I didnt search too long. Thanks!
Old Oct 6, 2011 | 02:05 AM
Any help is appreciated!!
Old Oct 6, 2011 | 10:22 AM
ProPilot04's Avatar
You mean you want to remove the black grill or the black mesh? You're going to use it to try and replace them on a damaged hood? Am I understanding this right?
Old Oct 6, 2011 | 10:35 AM
YogSaahoth's Avatar
Veteran: Army
just remove the clips and nuts from the underside of the hood and it pops right out...nothing fancy. theres like 3 or 4 of those circular metal pop clips and maybe 5 or 6 nuts. The aluminum vent thingy falls right off and the grill will come right out the top side of the hood.
Old Oct 6, 2011 | 02:33 PM
06RedRalli's Avatar
^ That's the answer.
Old Oct 6, 2011 | 04:08 PM
Thank you both. I have a gray hood i bought that i was going to paint red. Then i wound up finding a red hood without the grill and mesh... So i wanted to remove the mesh and grill and put it on the red hood. Thank you!
Old Jun 27, 2018 | 11:23 PM
Jp7's Avatar
Jp7
I know this is an old thread- but I am working on this as well.
I plan on removing both the mesh, and the louver part so I can repaint both.
These pictures are not mine, but it will show what I need to in order to ask the question I have.
The edge of the mesh screen has a rubber weather-strip of sorts. I raised the edge gently, and it looks to be only taped on.
Is it possible to remove the mesh only by itself so I don't have to mask this rubber portion off? I was planning on hitting this with some glass bead in my sand-blaster at low PSI to remove the original paint (which is chipping now)
Old Jun 28, 2018 | 06:13 AM
cleong's Avatar
As far as I can tell, you can't separate them without breaking something. The paint flakes off all the time due to heat. I just use a paint marker now and then and when it gets really bad I mask the frame and hit the whole thing with high temp black but the problem always comes back.
Old Jun 28, 2018 | 10:20 AM
Jp7's Avatar
Jp7
I just took it off the car. I see the mesh is sandwiched beween 2 pieces of metal. There are little spot welds holding it together. I was thinking of cutting these free so I can remove the mesh, but instead I will sandblast it as one piece. I removed the rubber trim. I was right, it was just taped on. It came off fairly easy with a little tender loving care. I will tape it back with the same style tape after painting is complete.
Old Jun 28, 2018 | 12:24 PM
Is2scooby's Avatar
Anybody ever powder coat one of these so they require less "upkeep"? If so, how did it go?
Old Jun 28, 2018 | 04:57 PM
Jp7's Avatar
Jp7
Maybe I'm the first.
So I removed the rubber shroud, and then pulled off the mesh and louver sheet. I use aircraft paint remover, compressed air and a power washer to get these cleaned up. I still plan on media-blasting or soda-blasting them. This took me 6 hours.
Old Jun 28, 2018 | 05:43 PM
hutch959's Avatar
nice work..
anxious to see the finished product.
Old Aug 1, 2018 | 11:48 PM
Jp7's Avatar
Jp7
Originally Posted by hutch959
nice work..
sorry for the delay, had this done for a few weeks now. Nothing to special to look at- just looks exactly like a new stock part. I'm happy with the results.
By the way- I think it is fairly impossible to re-tape the factory rubber strip like it comes from OEM. I tried this, and had a hell of a time reinstalling the part once it was taped on. The tape was getting it the way. Instead, I used a 2 part urethane activated adhesive. That worked much better.
Old Sep 3, 2018 | 09:52 PM
silverevo05's Avatar
did you ever consider leaving it plain aluminum or high heat silver paint?
ive seen a few GG evos with that and it looks good as in stands out?
Old Sep 4, 2018 | 01:26 AM
Jp7's Avatar
Jp7
Nah, I wanted it to look OEM. I have had it back together for a while now- haven't driven it this way yet to report anything useful.
