WALBRO 400 install evo 8
Old Oct 6, 2011 | 08:34 AM
dcamp56's Avatar
So i just wanna show this write up on how we got the pump to work! Not trying to be a vendor here.
MRP installed a walbro 400 pump in my EVO 8
First remove pump and grind down the pump hanger up to the first tabs, when you reach the tabs you no have to bevel the inside so the pump can slide in.
Once finished slide the pump in making sure it locks in tight and clip in the harness. The factory or walbro 255 harness clip straight into the pig tail that connect to the 400 pump
Install the filter and slide on the bottom cap and clip into the tabs, if you cant get the to clip in you may need to trim the hanger alittle more.
Re install the pump making sure it doesnt bottom out in the tank
Once in clip all the connector in and prim the system making sure the pump turns on. If pump doesn't turn on make sure you have everything connected correctly
thanks! any question feel free to PM me
Old Oct 6, 2011 | 08:53 AM
Ev0ikon's Avatar
Please! Someone grab the pics and repost them here. I can't see those pics from where I am.
Thanks a million! :}
Old Oct 6, 2011 | 08:56 AM
tim85851's Avatar
same here!!!
Old Oct 6, 2011 | 09:03 AM
mdsevo06's Avatar
Red X, need some Visine
Old Oct 6, 2011 | 09:05 AM
EvoDan2004's Avatar
I can see the pics.
But why are we posting this yet again? 3rd time now.
Old Oct 6, 2011 | 09:12 AM
Ev0ikon's Avatar
Originally Posted by evodan2004
I can see the pics.
Other threads are no where to be found. I am not sure why. I have yet to be able to see any pics even on previous threads.
Old Oct 6, 2011 | 09:17 AM
awdturbo8's Avatar
+2 on that ^^^^^^^^
Old Oct 6, 2011 | 09:24 AM
tsidrift1's Avatar
Doesnt look like much work is involved at all. Just have to be careful not to grind down the hanger to far, then you will need a new assembly. Just got to be precise and careful.
Old Oct 6, 2011 | 09:30 AM
Ev0ikon's Avatar
Just saw some pics on this thread:
https://www.evolutionm.net/forums/ev...y-info-15.html
Old Oct 6, 2011 | 10:06 AM
dcamp56's Avatar
I can see the pics.
BC it keeps getting deleted and i want people to know how to do it!
Old Oct 6, 2011 | 11:43 AM
Ev0ikon's Avatar
Thanks a bunch, even though I didn't get to your pictures!
Old Oct 6, 2011 | 11:51 AM
Pal215's Avatar
Thanks for posting this. There were a lot of people who said this was not possible, easy, or practical, but you proved otherwise.
Old Oct 6, 2011 | 11:52 AM
Pal215's Avatar
How does it sound btw? Is it no louder than the 255?
Old Oct 6, 2011 | 12:01 PM
5LEEPERISAH23I's Avatar
let us know if you have any problems with it. I want it but didnt want to be the ginny-pig with a modified fuel setup then be screwed
Old Oct 6, 2011 | 12:17 PM
nonschlont's Avatar
keep us posted... Intersted in this as well!
