Best turbo for 2.3 stroker
We made 605 on E85 31 spike falling to less than 25, you can run the same boost on pump gas with less timing no problem, if it didn't make WELL over 500 I would drive it off a life in utter embarrassment.
You're the only person I've heard of making those numbers on a green. Mostly everyone else is stuck at low 400's. My goal is 500 on pump gas. No e85 at all.
I will be back on pump soon enough too as the weather here is turning to crap, will leave the boost at about 30 spike falling to mid 20's, last time on pump gas and the Green was on my BR 2.0 and it ran a 10.8@137.7 not touching 30 psi, I love this turbo.
I have to bust in here.
Typically I see a really well set up car on a Green make low 400's here on our dyno on pump gas and it has to be a good set up. So on a Dynojet that's maybe 460'ish. For the "average" guy I don't think you should get your hopes up to see anywhere near the numbers Curt is putting out.
