Still confused..DW300 or Aeromotive 340
Old Oct 15, 2011 | 05:20 PM
superk1980's Avatar
Ok guys i've been reading and i'm still confused and i'm sure i'm still not the only one. Which pump is better DW300 or Aeromotive 340. Thanks for any input
Old Oct 15, 2011 | 07:46 PM
tsidrift1's Avatar
The new walbro400 will outflow both. Just have to mod the fuel pump housing a little. I would go with that.
Old Oct 16, 2011 | 10:40 PM
ProPilot04's Avatar
Better is a relative term. What are you trying to do?
I went with the DW301 personally. I just needed something to flow a bit more than stock and I wanted it to be silent.
Old Oct 17, 2011 | 02:32 AM
S13 Curtis's Avatar
walbro 400
Old Oct 17, 2011 | 05:47 AM
EvoFlash's Avatar
Is there a thread for what has to be done for the walbro 400? Also what is it rated for power wise?
Old Oct 17, 2011 | 06:03 AM
EmeryatSTM's Avatar
We have made over 580 whp on our mustang dyno with the new Walbro. With the other pumps we have only been able to reach a little over 500.
-Em
Old Oct 17, 2011 | 06:16 AM
EvoFlash's Avatar
Thanks emery. Here is a how to for the walbro 400 install seems simple.
https://www.evolutionm.net/forums/ev...ification.html
Old Oct 17, 2011 | 06:22 AM
superk1980's Avatar
Thanks guys. I just went with the Aeromotive 340. I know the big hype with the 400 but it's still too new to me so i will pass. My goal is only 500WHP on E85 so i think the Aeromotive 340 will do me well. Thanks for all the great input
Old Oct 17, 2011 | 06:38 AM
EmeryatSTM's Avatar
If you are using e-85 I strongly recommend not using any of those pumps. Do yourself a favor and go with the walbro.
-Em
Old Oct 17, 2011 | 07:30 AM
Broham's Avatar
Emery,
Besides modifying the housing, what else is required to run the new walbro? I understand a rewire allows to get the right voltage and handle more hp when you go over 500 etc, but what if one just runs pump for 93? Will the walbro work as a drop in without any rewiring or changing the fpr safely? Thanks man
Old Oct 17, 2011 | 07:43 AM
surferjeff's Avatar
the aeromotive flows the same as the walbro. I dynotested it and it ran out at 500whp
Old Oct 17, 2011 | 07:48 AM
superk1980's Avatar
Which walbro? 255 or 400?
Old Oct 17, 2011 | 09:24 AM
EmeryatSTM's Avatar
Yes the walbro will make about 500 whp on our dyno without the rewire kit on e-85.
Its not that the other pumps cant make power, Its just that they wont do it for long. They have been failing. There is a reason why the walbro is the shape that it is.
-Em
Old Oct 17, 2011 | 10:02 AM
Broham's Avatar
well there is no need then really for other pumps. just pop in the walbro and you're good to go. When you require more fuel rewire it. IF thats maxed, double pumper. game over
Thanks emery, i'd like to come to stm but man you guys are far!! I'll try to make it up there sometime
Old Oct 17, 2011 | 07:40 PM
killerpenguin21's Avatar
-Em
are you referring to e85 or on pump?
im not planning on ever making more than 400whp on VD, so i dlike to stay away from the 255's due to noise and the 400 due to need for a aftermarket FPR.
