hmmm whats this noise? (Video)
Old Oct 23, 2011 | 10:06 AM
bnr34rb26dett's Avatar
I hear this noise from where the serphine belt is. it makes ssssssssssssssss noise like air is leaking and possibly the belt scraping against some part. i have absolutely no idea where this noise is coming from. i changed my water pump, alternator about 2 months back. im losing no coolant. serphine belt does look damaged on the surface so i was thinking its hitting something but i really cant tell whats going on...
I sprayed around the engine bay to see no leaks. does anybody have a problem with pullies go bad after a while?
and comments/suggestiosn would be appreciated
Old Oct 23, 2011 | 10:54 AM
EvoDom's Avatar
You can deffinetly her a leak of some kind, could be a vacuum leak somewhere, I don't think your belt has anything to do with it. I would check the intake manifold for any leaks
Old Oct 23, 2011 | 10:59 AM
cfdfireman1's Avatar
exhaust leak
Old Oct 23, 2011 | 11:04 AM
Lancerguy'03's Avatar
Get a squirt bottle of soap and water and start spraying everything and see if you get bubbles anywhere.....
Old Oct 23, 2011 | 01:06 PM
ILoveAWD's Avatar
Would like a gasket on the external waste gate is blown..
Old Oct 23, 2011 | 02:35 PM
OneCrazykid's Avatar
i see no vid
Old Oct 30, 2011 | 08:21 AM
hmm its def not air leak. it seems to be something scraping.
do pullies go bad after certain miles??
Old Nov 4, 2011 | 09:22 AM
any opinions on pullies going bad so i can kind of pinpoint where to look? its not air leak
Old Nov 4, 2011 | 09:38 AM
dastallion951's Avatar
simple man just go one pulley at a time, pour a little bit of water directly on the pulley see if the noise goes away, if it comes right back its that pulley, if it dont go away, go to next pulley and repeat, if noise never subsides try a new belt idler pulley and tensioner.....pretty straightforward.
good luck
Old Nov 4, 2011 | 10:50 AM
good luck
wow water? that didnt even cross my mind.
ill give that a try
Old Nov 4, 2011 | 10:59 AM
wht95scort's Avatar
Take the drive belt off completely and start the car if the noise goes away you know its a pulley then just narrow it down
