steering wheel lock
Old Oct 25, 2011 | 04:20 PM
SunnyC's Avatar
steering wheel lock
is the steering wheel lock and ignition switch relocatable? does anybody have the diagram for this as well? i cant seem to find it online anywhere. has anybody even removed their steering wheel lock to be replaced?
Old Oct 25, 2011 | 05:31 PM
Ev0ikon's Avatar
The steering wheel lock is integrated in the key cylinder.
What are you trying to do?
Old Oct 25, 2011 | 06:28 PM
HN7's Avatar
HN7
^+1
Yep, you will have to grind and knock the pin that holds the steering lock out. After that you can put it back or relocate it to a different location.
Old Oct 25, 2011 | 07:02 PM
SunnyC's Avatar
okay I understand the 2 rivots and the bracket. it should still work even if it's relocated correct? well I want to install a push start but it still requires the key cylinder assembly, but I want it to be a clean look without the key slot.
Old Oct 25, 2011 | 07:49 PM
HN7's Avatar
HN7
Yep, it will works still. That's what I did too. I can't figure out how to disable the immobilizer so I just hide the key cylinder.
zasboy
Aug 11, 2013 07:05 AM
Jacoby
18
Dec 20, 2011 08:55 PM
EndlessRed
Apr 3, 2010 10:23 AM
Mitchubishievo
15
Oct 15, 2008 11:02 AM
Haris1977
Aug 10, 2004 10:45 AM
