hta
Old Oct 29, 2011 | 08:00 AM
alenewit3928's Avatar
hta
What's the spool difference between the hta82 and the hta86. I'll be using this on a 2.3 for street and highway. No events.
Old Oct 29, 2011 | 10:24 AM
EvoJoeIX's Avatar
Only a few hudred rpms difference in spool, but the hta86 makes up for it on the top end
Old Oct 29, 2011 | 12:26 PM
I want 525wheel on pump and ballpark 600wheel on e85
Old Oct 29, 2011 | 05:39 PM
EvoJoeIX's Avatar
The 82 will be fine for your power goals
Old Oct 29, 2011 | 06:02 PM
05blue8's Avatar
The 86 has been proven to make 800+, the 3582 will hit surpass 600 on e85. Either turbo will work
Old Oct 30, 2011 | 02:20 PM
DaveEarlEarl's Avatar
The 82 will definitely hit your goals. Also the slightly quicker spool is nicer.
Old Oct 30, 2011 | 02:42 PM
will I have to push the 82 harder to make it, or will it be just as easy?
Old Oct 30, 2011 | 02:46 PM
TurboTravis's Avatar
You'll have to run more boost on the 82 than the 86 to make the same peak hp numbers.
Old Oct 30, 2011 | 02:49 PM
Kracka's Avatar
https://www.evolutionm.net/forums/ev...omparison.html
Old Oct 30, 2011 | 06:21 PM
Mikey@Spec-Ops's Avatar
Brother, you will be fine with the 3582. I think a 3586 is a bit overkill for you unless you want the extra room to grow in the future. The 3582 will make 650-700 easy on E85.
Mikey
Old Oct 30, 2011 | 06:27 PM
Does anyone have dyno graphs with the 82?
Old Nov 2, 2011 | 04:41 PM
acdavis25's Avatar
read through the link the mod posted above. there's a graph in the very first post.
Old Nov 2, 2011 | 05:06 PM
Thanks and I saw that. I'm actually talking about the 3582
Old Nov 2, 2011 | 08:47 PM
acdavis25's Avatar
here you go
https://www.evolutionm.net/forums/ev...light=hta+3582
