please Help!!! need advice asap
Old Nov 9, 2011 | 01:09 PM
Blue_05EVO's Avatar
Ok really hoping sombody responds, I bought on 05 EVO 8....guy said It was tuned to 23psi ...doesn't have a wideband!..and te car isn't running right...the boost gauge.only reads up to 20 people and it spikes well over that at WOT...
Is there any way to reset the ecu and use the mbc to turn Tue boost back down to 20
Old Nov 9, 2011 | 01:18 PM
danextreyes7's Avatar
if i was u i would turn the mbc till it was closed and just run off the wastegate, dont beat on the car and have your local tuner just re flash the ecu for u to w.e boost level your turning to run providing he has a wideband to monitor your afr's
Old Nov 9, 2011 | 05:55 PM
Blue_05EVO's Avatar
I posted on here asking if anyone had tuning software that could help me, but know one seems to want to respond. I think the closest buisness is Bushur which is 4 hours and chicago which is 4 hours lol.
So if anyone could help me oiut that is around indiana or INDY i would much appreciate it.
Also the car is not running BAD!!...it just doesnt have a lot of pull/ power...
my gas mileage is about 250 per tank...
it has a forge BOV can those be set? could it be leaking?
Old Nov 9, 2011 | 06:14 PM
Blue_05EVO's Avatar
Also....I just looked at the forge bov.....the base of it is attached to the turbo intake....and the side recirc opening is attachingd to the uipc??!!! Now if I'm not mistaken isn't that backward????...
Old Nov 9, 2011 | 11:36 PM
Blue_05EVO's Avatar
Here's a good question that I've searched for but.couldn't find.....
I have a SES light on for the cat being gone......could this cause the ecu to act different...even if it was supposedly tuned.....
Old Nov 9, 2011 | 11:51 PM
barneyb's Avatar
No
Old Nov 10, 2011 | 12:45 AM
Blue_05EVO's Avatar
Well scratch that then....I guess the best way is to have it re tuned....if I can get anyone on here from indiana.....have yet to get anyone to answer my thread in the.Midwest....
Old Nov 10, 2011 | 12:51 AM
EVO8emUp's Avatar
No you didn't.
Ask and you shall receive...
Old Nov 10, 2011 | 01:47 AM
Blue_05EVO's Avatar
[QUOTE=Ask and you shall receive...[/QUOTE]
Hey guys, is there anyone near Indy...specificky east side that coyld help me with ny tuning.....I don't have any software or knowledge of EVO tuning.....thanks
Old Nov 10, 2011 | 05:01 PM
PRS's Avatar
PRS
Theres many tuners that will do e tunes. All you need is a tatrix cable. I would however suggest buying a wideband first and have it installed. A manual boost controller would allow you to lower boost easily
Old Nov 10, 2011 | 06:31 PM
Blue_05EVO's Avatar
I'm .looking for someone around who already has one to help me.out....o wanna get this fixed quick...and don't kmow where to behind scum if I had a cable
Old Nov 10, 2011 | 06:35 PM
EvoJoeIX's Avatar
Everything you would need to know to get an etune can be found in the ecu section here. Its not hard to do at all
Old Nov 10, 2011 | 06:53 PM
Blue_05EVO's Avatar
Ok ill read and read lol....but I don't want my car to be getting hurt until I can......these are more expensive than eclipses.lol
Old Nov 10, 2011 | 07:02 PM
EvoJoeIX's Avatar
Just stay out of boost until you get it figured out.
Id contact arron at english racing bout the etune. I know hes done a bunch of cars on here with great results. He'll make sure your car is 100%
Old Nov 10, 2011 | 08:23 PM
Blue_05EVO's Avatar
I've searched and what I have found is a need for laptop(check), tactix cable, tuning software, and flash roms......then experience.....IS this sum.it up.....or is there a sticky somewhere I'm missing that explains
