AEM UEGo into cabin.
I'm having the biggest trouble finishing my AEM UEGo into the cabin. I have a AMS downpipe w/the O2 bong welded in. The bong is on the left side of the downpipe and points to the drivers side. i found one of rubber grommets but if i fished it through that hole it would come up underneath the drivers side floor. Is this the right one??? If anyone has pictures of their install or a link to a install that would be GREAT! thanks
It should go up through the passenger side footwell... I'll look for pictures of my install.
Basically, remove your passenger side carpet, and you'll see a grommet in that area. A little to the left by the center console if my memory serves me right...
PM me if you need more help
i just installed mine the other day and my bung is on the driver side just like yours. i ran it up the drivers side by the master cylinder, and then along the firewall to the passenger side where there is a little hole plugged with a rubber grommet. u can slice the rubber piece and put the plug and wire through it. i removed my glove box and ran it along the metal tube behind the dash. also, if your going to data log i would recommend that you run the blue and white wires so that they sit in your glove box. i didnt take any pictures but the wire is long enough to run up the drivers side.
I just removed the stock rear O2 sensor and used that hole to install my UEGO.
The hole comes out in the passenger side footwell behind the shift console piece.
You will have to make the hole slightly bigger from the inside with a dremel so you can put the UEGO sensor through.
You will get a CEL for disconecting the stock O2 but that can be fixed in the ECU.
not the aem unit but i ran my innovate wideband from the passenger side. It pops out underneath the pass seat and you can fish it through underneath the carpet to where ever you want to go with it.
good luck
