running rich! ahhh
Old Nov 30, 2011 | 10:47 AM
vinnieg's Avatar
running rich! ahhh
Hooked up my air fuel ratio gauge and its reading 10.0 at idle and around 70mph it reads 11.4 i know I might be wrong and correct me if I am but shouldn't it be around 14.7 at idle? How do I lean the car down I got an aem ems I was thinking that's how but I'm not sure in what setting that would be I need some help! Thanks guys
Old Nov 30, 2011 | 10:52 AM
SDevo13's Avatar
There are several very good tuners near you. I would make a call to them. If you are having issues finding the start map/idle map on your AEM, I wouldn't be trying to tune via internet advice.
Old Nov 30, 2011 | 01:02 PM
GTRicky's Avatar
yea, 14.7 is stoich, but depending on the mods you're running, you may want to run a little bit richer. What mods do you have?
Old Nov 30, 2011 | 01:10 PM
Tony the Tiger's Avatar
A rough guideline for AFR's should be:
Idle = 13.5 - 15.0:1 AFR, this would depend on your injectors, cams, etc.. to achieve smoothest idle.
Cruising, low/med RPM's = 14.5 - 15.0:1 AFR
Cruising, high RPM's (>5000) = 13.8 - 14.2:1 AFR
0-vac / entering boost = 12.5 - 13.0:1 AFR
Full boost = depends on your setup and fuel, but usually 10.5 - 11.5.1 AFR on gasoline
Old Nov 30, 2011 | 01:20 PM
mdsevo06's Avatar
Could be the sensor for the AFR, they don't last long. If you put it on a dyno, it will tell the truth.
Old Dec 1, 2011 | 04:04 AM
vinnieg's Avatar
I run pump fuel and I have a few mods but my fuel system was upgraded its a double pumper walbro fuel pressure regulator. My car looks like a diesel truck when I take off haha
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
geraldrepuyan
May 30, 2017 04:26 PM
youra6
Jan 22, 2016 10:03 PM
ridenrunwv
Oct 2, 2015 01:24 PM
henrymm
Oct 14, 2006 08:29 PM
