Bad IAC?
Old Feb 9, 2012 | 03:07 PM
  #31
black_beauty's Avatar
how do you disable this in evoscan? Is it the "ISC Steps"? Thanks
Old Feb 9, 2012 | 05:53 PM
  #32
warstang27's Avatar
Iacs go bad on 8s a lot, test the voltage. Even then it could just have a lot of carbon buildup in it. I've had to pull mine off before and clean it with some seafoam and a toothbrush. If you do need a new iac look for a working used evo 9 one here, the 9s teeth are metal so they don't go bad nearly as often
Old Jul 23, 2012 | 06:57 PM
  #33
sjjrad's Avatar
How could you tell the difference thou if it's the iac over being the iac sensor?
Old Dec 17, 2017 | 11:33 PM
  #34
Boost411's Avatar
Originally Posted by Dmav1989
Mine goes to 2k for a couple secs and trickles down to 1000-1100 and idles there and then randomly at a light sitting there it drops to 300 and pops back to abt 1000 and wideband gauge shows 11.0 or lower very rich and most of the time it's fine until those random idle dips comes around
did you ever figure out the problem?
evo8.03
Dec 24, 2020 09:33 PM
The_Cleaner
Dec 12, 2017 11:12 AM
benIX
Nov 14, 2017 12:49 PM
xiMR
Aug 18, 2016 08:36 AM
GSXPimp
Feb 17, 2016 06:15 AM
