Quick question on AEM wideband
Old Dec 28, 2011 | 05:19 PM
endlesss's Avatar
Originally Posted by sujinX
when my digital goes below, the gauges just reads 10.0 when it goes lean it just reads --- if i recall correctly.
That's how mine works.
Old Dec 28, 2011 | 06:32 PM
dastallion951's Avatar
get the digital it looks better plus you get an accurate reading down to the tenth of a point on the afr, where the analog its kinda guess work. Im happy with mine, 35k on it no real issues with it. Go digital save the analog for your boost gauge.
Old Dec 28, 2011 | 06:57 PM
endlesss's Avatar
35k on original sensor too? Glad to hear these last I don't have more than 2k on mine. Hoping it lasts that long.
Old Dec 28, 2011 | 10:18 PM
lalu's Avatar
Originally Posted by 06RedRalli
You should go by what your gauge is telling you. The tailpipe sniffers are going to be off. The location of your wideband measures the true afr's.
Great! That's what I have in mind too. I thought I was having a bad batch.
Old Dec 28, 2011 | 10:19 PM
lalu's Avatar
Originally Posted by deylag
I would say that the value that is read from the dyno is the more accurate value.
ulpps...doesn't sound good.
Old Dec 28, 2011 | 10:20 PM
lalu's Avatar
Originally Posted by Butt Dyno
You think reading the AFRs at the tailpipe is more accurate than reading it closer to the turbo?
I have the same question.
Old Dec 28, 2011 | 10:21 PM
06RedRalli's Avatar
Gotta think that the tailpipe sniffer is going to get just a tad bit of outside air due to it's location at the end of the exhaust. It won't be much outside air but it is enough to throw off the true afr's.
Old Dec 28, 2011 | 10:32 PM
lalu's Avatar
Just wondering, the tailpipe position does affect the afr on idle but not sure when there's a constant flow of exhaust gas at high rpm. I would have thought there's at least a delay in readings but the actual afrs remain the same regardless of the positions of the sensor? Hope it makes sense lol.
Old Dec 28, 2011 | 10:40 PM
lalu's Avatar
Has anyone made afr comparisons between aem and dynos? Do the values differ a lot?
Old Dec 28, 2011 | 10:49 PM
lalu's Avatar
Also, at what rpm do you start seeing 11 afr? As soon as you wot?
Still learning my new toy!
I must say this site has been really helpful!
Old Dec 29, 2011 | 08:04 AM
usnevo8's Avatar
I have the aem analog and it read from 8.5-18. Its nice & I love the way the dial sweeps but get a different one so yo can run with evoscan if you do that or have any interest in doing that
Old Dec 30, 2011 | 08:27 AM
black_beauty's Avatar
Digital is very nice, and you can log with it. Its nice not to have to eyeball the AFR's during pulls lol
Old Dec 30, 2011 | 09:36 AM
GTijoejoe's Avatar
I've had my Zeit. unit for a very long time.... since 2005 probably, the original unit and sensor... for well over 55k miles.... and its been mounted at 3 o'clock the entire time... its been so long I can't really give you an exact time frame or mileage lol
Lets just say I like it so much I bought another for my evo..... original is on my GTi
Old Dec 30, 2011 | 11:52 AM
to be honest the tailpipe sniffers only work to monitor afrs as long as you dont have an exhaust leak at any flanges, or manifold to turbo/head. Any small leak can still throw your afr off a few points. My aem wideband is mounted on downpipe before cat flange. I like it, only thing I wish is I wouldnt have went cheap n bought an autometer boost gauge is like 1 or 2 psi off on reading, but an analog and digital gauge, looks ok but ive got mine on the steering column pod. Too many distractions, but I didnt want the jet fighter cockpit look on the A pillar haha
Old Dec 30, 2011 | 12:20 PM
DKz779's Avatar
+1
a properly mounted wideband and tailpipe sniffers are only accurate if you have NO exhaust leaks. why do you think tuners want to check for exhaust leaks before starting the tuning process.
Insanity Evo
Jun 14, 2016 06:45 AM
seven10
Sep 18, 2015 03:49 PM
texasevo
Aug 27, 2015 09:31 PM
texasevo
Aug 27, 2015 09:14 PM
RealStreet
EvoX 'For Sale' Electronics / Lighting / Audio
Jul 25, 2012 09:58 AM
