a vibration when i drive
Old Jan 6, 2012 | 05:11 PM
ahmed moustafa's Avatar
hi all
i have a problem with my evo9 i feel a vibration when i drive my car especially when i take the curves it seems like a failure in the drive shaft i have change the clutch kit and the cv joint and every thing is normal !!!! plz help
Old Jan 6, 2012 | 05:30 PM
lanberg's Avatar
this might be stupid, I dont even have an evo yet, but could it be motor mounts?
Old Jan 7, 2012 | 01:29 AM
thanks lanberg for reply but i have checked out all the mounts the engine and the gearbox and i replace it with a new one and the same prob still
Old Jan 7, 2012 | 01:56 AM
digitalskillz's Avatar
What mods have you done?
Could be a problem with wheels not mounted correctly
Does it feel like it has to do with the engine RPM's? Or does it vibrate while coasting?
Old Jan 7, 2012 | 07:32 AM
thepoint4life23's Avatar
Could be many things such as bad tires out of balance wheels and tires
Old Jan 7, 2012 | 08:04 AM
deadmeat's Avatar
The last time I felt my car vibrating I lost a wheel at 70 mph on the highway.
Check those wheels/lug nuts!
Old Jan 7, 2012 | 04:00 PM
kEvOlution VIII's Avatar
i have a very similar problem
Old Jan 7, 2012 | 06:56 PM
TREDMKV's Avatar
Wow why post this if you don't even give a good description on whats going on. MPH range the vibration starts, can it be felt in the steering wheel or just the body of the vehicle, and any other information you might think that is related to the issue.
Old Jan 7, 2012 | 07:02 PM
Dube's Avatar
Maybe a bad wheel bearing?
Old Jan 8, 2012 | 07:50 AM
TommiM's Avatar
You didnt give much details about your concern, but maybe it could be the driveshaft carrier bearing going bad.
Old Jan 12, 2012 | 11:32 AM
ok guys the proplem is i feel a vibration in the body of the car while coasting with it at 50 mph and i have changed the clutch kit and all the bushes and also balancing the tires i have checkout the mounts of the gearbox and the engine so what it could be ?
