Cam install torque spec question
Old Jan 27, 2012 | 11:10 PM
DormantBeast's Avatar
hey guys doing a Cam install and the service manuala torque specs look wonky to me they seem pretty low and they felt tighter when u was taking them off... should I be concerned or should I just shut up and follow the ? lol
Old Jan 27, 2012 | 11:20 PM
TheBoz's Avatar
Just make sure that the Cam Angle Sensor thing that attaches to the Cam Shaft is only torqued to 16-18ftlbs. On the FSM I have it said 90+ftlbs, which was way wrong.
Old Jan 27, 2012 | 11:43 PM
the manual says 14 N.m = 10.32587 ft pounds this correct ?
Old Jan 28, 2012 | 12:18 AM
okevolutionVIII's Avatar
15 ft lbs on the bearing caps and 65 ft lbs on the cam gear bolts are where you should be. CAS was at 15 I believe. They may seem low but the head is made of aluminum and a torque wrench puts more leverage on a bolt than you think.
Old Jan 28, 2012 | 01:14 AM
ok so this was prior but one of the camshaft position sensor cover bolts got stripped a bit can I use one from the spark plug cover ?? they are same except the spark one is a lil lil shorter can I use to replace? thnx for any help and to those who have:-)
Old Feb 2, 2014 | 07:52 PM
speifer's Avatar
THIS!!!!! ^^^^^
I just ruined my camshaft by following this manual. It said 98 ft-lbs which is WRONG. It should be 16 ft-lbs. I unfortunately realized this too late. Who freaking wrote that manual?
Tobra
Lancer Tranny/Drivetrain Tech
Jun 3, 2017 08:17 PM
BoostingHard
13
Sep 1, 2014 07:33 PM
egokiller
May 20, 2013 10:46 AM
EvoAznBoi
Nov 28, 2011 09:35 AM
powerspeed06
Mar 5, 2011 04:58 PM
