Best Boost Controller?
Old Jan 31, 2012 | 06:34 AM
Mauricio Evo IV's Avatar
Originally Posted by chu
Depends on whether you want to get a manual boost controller, or run ECU boost. There are positives and negatives to both methods. I've ran both setups; Hallman Pro RX for manual, and Perrin EBCS w/ JDM 3 bar for ecu boost control.
Negatives whith for example grimmspeed 3 port??
Old Jan 31, 2012 | 08:18 AM
blknblubkrdude's Avatar
I have been running a Hallman Pro for a couple years without incident.
I originally installed a Grimmspeed EBC (ecu controlled) and the tuner (a well known, respected one) was having problems tuning with it.
He'd be doing fine for 5 pulls, then we'd have overboost.
Then two runs later it would be down on boost. We put a MBC in and it never had a problem.
Although a EBC can technically perform better, I like the simplicity of a MBC.
Old Jan 31, 2012 | 08:52 AM
icrnk's Avatar
Originally Posted by Mauricio Evo IV
Grimmspeed MBC... but, I´m switching to a grimmspeed 3 port in the next months!
Grimmspeed made in
Old Jan 31, 2012 | 10:44 AM
CJ2X's Avatar
I haven't heard of any negatives. I'm sure someone else can chime in though.
Why run an Electronic BCS over a Manual Boost Controller?
A MBC allows you to run higher than stock boost levels by preventing the wastegate from opening at its rated pressure. It does a great job at this but if boost is available under the MBC setting it will give you that full boost. So for instance, you set your MBC to 18psi because from 3000-6000rpm that's what you want. But then say you get detonation with 18psi when you are at 7000rpm unless you are below 16psi. With a MBC, you do not have this control so you are forced to run 16psi through the entire rev range. With an electronic boost controller you could run 18psi from 3000-6000 and 16psi at 7000rpm because you can tune the boost map in the ECU which will allow you to run the maximum amount of boost at every given rpm. This gives you more power throughout the range and better control. Revolutionizing the EVO boost solenoid market, we have created model specific install brackets that allow you to directly fit our Boost Solenoid into your EVO for a factory fit. No more Zip-tying! We give you the factory fitment you have been waiting for.
Old Jan 31, 2012 | 11:26 AM
Spec-Ops1's Avatar
I can't stand ECU controlled boost, do it simple and get a MBC and be done...
Old Jan 31, 2012 | 11:52 AM
gsrboi80's Avatar
I have had the same Hallman MBC on my car for like 5 years. Never an issue. I can't stand EBC's.
Old Jan 31, 2012 | 12:08 PM
rick1024's Avatar
i have a tru-boost in mine
Old Jan 31, 2012 | 12:11 PM
nollij's Avatar
Tuners like MBCs because they are simple and only require one setting. They don't like EBCs because they require more time to tune. Even if they do an EBC for you, they might not want to spend the time required to get every ounce out of the entire powerband.
You will get more out of your tune with an EBC.
Old Jan 31, 2012 | 12:55 PM
SmurfZilla's Avatar
I have learned to appreciate some of the safe guards you can utilize with ECU controlled boost.
Old Feb 1, 2012 | 05:14 PM
Fisher2989's Avatar
Hallman all day
Old Feb 1, 2012 | 10:08 PM
lanberg's Avatar
Originally Posted by notjdm05MR
You will not need that to exceed 29 PSI. You can do that with a manual boost controller. Also you shouldn't base your goals on a certain boost level!
No I wasnt, I was asking where my boost should be when my car is about 400hp, because this boost gauge doesnt adjust past 29 psi ( it says it on the link )
Old Feb 1, 2012 | 10:13 PM
lanberg's Avatar
I think im going to get a hallman now lol.
Old Feb 1, 2012 | 11:42 PM
dee242's Avatar
Originally Posted by EmeryatSTM
We use Hallman Pro MBC's in all the cars we build here including Ricer.
They can be found here.
http://www.streettunedmotorsports.co...ccessories.htm
nut how do u know when to stop turning to get to a certain psi
Old Feb 2, 2012 | 06:44 AM
Spec-Ops1's Avatar
you turn the boost up a bit at a time... you wanna tune that way anyway...
Old Feb 2, 2012 | 06:45 AM
badev0's Avatar
Manual: Hallman Pro
ECU boost: Grimmspeed 3 port.
I've used both on my car, and both are nothing but excellent.
