$750 to install cams and valve springs!?
Old Feb 14, 2012 | 10:27 AM
EvoRinga's Avatar
I've asked for a quote from a local shop to install cams and valve springs and they quoted me 450 for cams and 300 for the valve springs. Seems kind of outrageous since I paid 650 for the cams and springs..
Old Feb 14, 2012 | 10:36 AM
CurseDSM's Avatar
Honestly that isn't to bad. I did my own with a spring compressor and a air compressor. But think about it, if they don't take the head off the car they are doing the same thing, doing the timing belt etc there is a lot that actually goes into it. So time is invovled. Take that into consideration.
Old Feb 14, 2012 | 10:43 AM
phi79's Avatar
Few shop in GA charge $250-$300 for the cam.
Old Feb 14, 2012 | 10:45 AM
gsrboi80's Avatar
That is way too much, if you ask me they are about 250-300 too high. They likely don't really want the job so bid it high.
So glad I don't have to pay people to work on my car.
Old Feb 14, 2012 | 10:49 AM
cody92talon's Avatar
450 to do the cams ok because of all the timing removal stuff. but what i dont understand is why its another 300 to do the springs when the cams will already be out if should take only maybe a hr to change the springs once the cams are out
Old Feb 14, 2012 | 10:50 AM
Boltz.'s Avatar
FCOTM Winner
Wrong. ^
To the OP, the price you were quoted is legit.
Old Feb 14, 2012 | 10:52 AM
Boltz.'s Avatar
FCOTM Winner
Just checked AllDataPro, Quote time is 8.8 hours to do the valve springs.
Old Feb 14, 2012 | 10:54 AM
CurseDSM's Avatar
Damn I am slow took me 2 days because I couldn't get proper tension on the t belt.
Old Feb 14, 2012 | 10:59 AM
AWD96's Avatar
Valvespring compressor tools are not fun. Its definitely a 2 person job. If you want it done right, you are going to pay.
Old Feb 14, 2012 | 11:07 AM
Lukelis's Avatar
My friend helped me, and we changed cams, springs and retainers for about 4 hous for mivec
Old Feb 14, 2012 | 12:08 PM
todd6027's Avatar
if they are taking off the head to do the springs then yes , if they have the tools to do the springs with the head on which they should have , then its a 4 hour job 5 at the most
Old Feb 14, 2012 | 12:23 PM
CurseDSM's Avatar
http://www.euroexportinc.com/store/t...ompressor.html
That one is the one I used and it wasn't to bad.
Old Feb 14, 2012 | 12:28 PM
gsrboi80's Avatar
Wrong. ^
Wrong ^, OP the 750 you were quoted is ridiculous. Of course assuming they are not removing the head which is stupid with the correct tools
Old Feb 14, 2012 | 12:30 PM
CAD EVO's Avatar
FYI had my cams and valve springs installed for $500 in Long Island.
Old Feb 14, 2012 | 12:37 PM
gsrboi80's Avatar
And there you go .
Hell even pulling the head to do cams, springs, retainers, and studs the car was back together way under 8 hrs
