Ignition Fuse keeps blowing
Old Mar 2, 2012 | 10:51 AM
keeler's Avatar
I'm trying figure out why my Number 8 20amp ignition fuse keeps blowing. I'm at a loss. It randomly wouldn't start yesterday so I checked and the fuse was blown. I tried unplugging both 02 sensors, coil packs, and two other plugs, I think one was the CAS and the other was next to the front 02 sensor on the valve cover.
Anyone have any ideas why it would do this?
Old Mar 2, 2012 | 10:57 AM
boosted91t's Avatar
Edit.. misread the question. Check for any frayed wires, you might need a wiring diagram and get out the multimeter, check for continuity with the ignition wiring and a ground source.
Old Mar 2, 2012 | 11:06 AM
keeler's Avatar
Know where I could find a good wiring diagram? I'm not good with electrical issues but I'll try anything. The car is stranded on the side of the road and Id rather it not stay there.
Old Mar 2, 2012 | 11:07 AM
boosted91t's Avatar
https://www.evolutionm.net/forums/ev...ram-maual.html
Old Mar 2, 2012 | 11:11 AM
keeler's Avatar
Thank you! Hopefully I can decipher this and figure out the issue
Old Mar 2, 2012 | 11:27 AM
keeler's Avatar
Well I went underneath of the steering wheel and swapped every relay with another one...it started right up and didn't blow a fuse. So I am not sure what the issue was, hopefully it doesn't return
Old Mar 2, 2012 | 03:11 PM
Murf's Avatar
Do you have something wired into that circuit that is not factory? If so its propbly pulling enough current to pop the fuse.
AlexC330NY
Lancer Troubleshooting
Mar 29, 2016 08:36 AM
Hell_Spawn
Jun 12, 2014 08:16 AM
a4rontran
May 3, 2013 09:25 AM
Tagge
23
Jul 30, 2012 01:50 PM
12secDD
Feb 25, 2012 09:42 AM
