Bad misfire @5-6k...help please
Old Mar 3, 2012 | 01:28 PM
SinisT3rSRT's Avatar
Ok another issue, to start off, car has 255 fuel pump, 1000cc injectors, jun cams, ams built ect ect.. I noticed it started mis firing about 2 weeks ago if you was to get wot, but it got worse, now it seems one whole cylinderr if not 2 isnt firing, idles perfect, normal driving is great as well, always shell or bp 93 oct or 110, its not bad gas...I changed the plug wires and spark plugs, same **** still happens...
Old Mar 3, 2012 | 01:33 PM
evo8426's Avatar
Speed density or MAF? What is the spark plug gap set at? When was the car last tuned?
Old Mar 3, 2012 | 01:50 PM
.023- car is tuned at 22psi pump gas... im thinking it's one of the factory coil packs.. its was tuned and maped by Chris at AMS...I bought the car from a guy that had her to 50k miles...20k on build..it ran great for about 6 weeks then this happened.. MAF Hmm maybe ill look at the sensor real fast
Old Mar 3, 2012 | 07:31 PM
techghost's Avatar
Or maybe dirty injectors who loses spray pattern and capacity to fuel engine at high rpms?
Old Mar 3, 2012 | 09:10 PM
3K's Avatar
3K
Check for boost leaks.
awdordie
17
Feb 26, 2017 09:16 PM
sti"izzle"
Mar 6, 2011 12:31 PM
mxguy1286
Jan 26, 2011 03:53 PM
MATT@WORKS
Apr 2, 2008 01:10 PM
UDLOZ2
Jan 26, 2008 07:42 AM
